DAYTON IMM-6 Calibrated microphone for iPhone iPad and Android
4.8 / 5
Reference : 8194
23,90 €tax incl.
19,92 € tax excl.
Grantie 5 ans
Dayton Audio IMM-6 Calibrated Microphone for iPhone iPad and Android
The Dayton Audio IMM-6 is a professional-grade audio measurement tool and recording microphone designed to work with Apple's complete "iDevices" - iPad, iPhone and iPod.
Its robust and compact construction makes it the ideal companion for audio professionals who want to perform acoustic analysis, audio level monitoring or just record.
Also compatible with Android and Microsoft devices that use a 3.5mm / TRRS jack.
  • Program for iPhone: AudioTools app (from Studio Six Digital)
  • Program for Android: AudioTool by Bofinit Corporation
Downloading the configuration file to use the IMM-6
Features:
  • For use with an iPad, iPhone, iPod Touch via 3.5mm Jack
  • Compatible with Android and Windows Phone devices with 3.5mm jack
  • Frequency response: 18-20,000 Hz (calibrated)
  • Impedance: 200 ohms
  • Sensitivity at 1 kHz, 1K ohm: 10 mV / Pa (-40 dBV, re 0dB = 1V / Pa)
  • Maximum SPL for 1% THD @ 1000Hz: 127 dB
  • Signal to noise ratio: 70 dB
  • Connector: gold-plated Jack 3.5 mm
  • Weight: 7.6 grams
https://www.audiophonics.fr/images2/8194/8194_daytonaudio_IMM-6_mocrophone_thumbs.png
https://www.audiophonics.fr/images2/8194/8194_daytonaudio_IMM-6_mocrophone_1.jpg
https://www.audiophonics.fr/images2/8194/8194_daytonaudio_IMM-6_mocrophone_3.jpg
https://www.audiophonics.fr/images2/8194/8194_daytonaudio_IMM-6_mocrophone_2.jpg
5 reviews
efficace
achat micro pour calibration application Wiim " room correction" amelioration des resultats dans mon cas avec un Ipad par rapport au micro interne, un bon investissement !
This review has been posted for DAYTON IMM-6 Calibrated microphone for iPhone iPad and Android
Très satisfait
Fonctionne parfaitement sous Windows 10 avec un Splitter TRRS ainsi qu'un câble TRRS pour pouvoir le positionner à l'endroit voulu.
Je l'ai utilisé avec son fichier de calibration sous Room Eq Wizard pour calibrer mes enceinte. Ca fait parfaitement le job pour pas chère.
Pour améliorer la mesure du niveau sonore sur un smartphone
J'ai acheté ce micro pour améliorer la mesure du niveau sonore sur un smartphone Android par rapport au micro interne.
Il fonctionne très bien avec AudiTool. La calibration fournie par Dayton concerne la calibration relative bande par bande. Mais il faut faire une calibration absolue avec un sonomètre de référence.
Le micro est livré dans une belle boîte métallique qui aurait pu être plus petite pour un transport plus facile et avec une mousse qui serre moins le micro pour le sortir plus facilement.
Visiblement un bon achat. A confirmer par la suite car je viens de le recevoir et, confinement oblige, je n'ai pas pu le tester en spectacle.
Cheap and functional, a little fragile
I bought the IMM-6 for measuring the frequency response of in-ear-monitors (IEM). With a simple piece of hose as a coupler with the IEM this works easiy with the FFT iPhone app. The results cannot be compared with a professional measurement but for comparisons they are very useful.
The 3,5mm female connector is a little tight on my model, and the microphone came apart when I tried to pull off the coupler. I was able to fix it.
For the price it is still a great option, and I recommend it, you just have to be a little careful.
Fait le job.
Je l'utilise avec l'application 'Audiotool' sous android.
Cela me permet de :
- préparer le volume sonore d'un test (C-curve, SPL)
- Mesurer à plusieurs endroits un sweep.
- Importer le tout dans REW pour travaux ...
A priori niveau SPL relativement correct (Pas de grosse erreur à priori par rapport aux retours sur le web) et surtout cohérence des mesures (D'une mesure à l'autre, elles sont comparables de façon relative. Les unes par rapport aux autres).
Ce qui est largement suffisant pour un réglage des niveaux par Fréquences pour générer un filtre FIR, une analyse RT60, checker la polarité d'un système.
La limite sous android : les mesures liées au temps: time-delay, phase etc ... là pas de solution.
Ceci dit, mes premiers tests me montrent qu'avec une prise jack 3 points des mesures sous REW sont possible directement sur un PC. (Prise en compte de la calibration micro, mais niveaux sonore surement faux)
Bref, un outil pour bidouilleurs mais qui à le mérite d'un rapport possibilités / prix imbattable.
