By buying this product you get 55 loyalty points
Ambisonic USB Microphone 32bit 192kHz ASIO Dirac
The AmbiMIK-1 from MiniDSP is a FOA (First Order Ambisonic) ambisonic microphone with built-in preamplifier, analog-to-digital converter (ADC) and USB processor. This compact, portable solution provides high-resolution sound capture up to 32bit 192kHz. Suitable for Virtual Reality (VR), Augmented Reality (AR) or music recording applications, the AmbiMIK-1 does not require the use of an external preamplifier or XLR cables. A simple USB cable connects the microphone to a computer or tablet.
With 4 low noise 14mm low noise capsules, a thin Aluminium body and a Nylon protective cover, the AmbiMIK-1 has been designed and engineered to offer excellent durability and performance at an affordable price. In addition, MiniDSP has worked with Dirac Research to develop a VST plugin calibrated specifically for the AmbiMIK-1 using more than 1200 measurements. The controls allow to act on the Yaw, Pitch and Roll parameters, as well as on the output gain or the output format (B or Binaural format).
Product type | Ambisonic Microphone (FOA) |
Connectivity | USB 2.0 Sampling rate : up to 32bit 192kHz |
USB Controller | XMOS 500MHz multicore processor |
Integrated preamplifier | |
ADC | ADC 32bit with integrated PGA for analogic gain up to 60dB SNR : 120dB Gain control via Mac / Windows app |
Capsules | 4x Low noise cardioid capsules, 14mm pre-polarized condenser Max SPL : 127dB SPL Self Noise : 16dB SPL Format Layout : Ch1 - Front Left Up (FLU), Ch2 - Front Right Down (FRD), Ch3 - Back Left Down (BLD), Cha4 - Back Right Up (BRU) |
Software | VST Plugin (Mac/Win) by Dirac Research specifically calibrated for AmbiMIK-1 Switchable output: B Format or Binaural Controls : Output gain, Yaw, Pitch, Roll |
USB Audio | Linux / OSX / Android driverless ASIO compatible driver for Windows iOS support via USB Camera Kit |
Body material | Aluminium |
Color | Gray |
Dimensions | 42 x 213mm |
Weight | 130g |
Package | 1x MiniDSP AmbiMIK-1 1x Tripod with microphone clamp 1x Wind screen 1x USB cable 2m |
