MINIDSP AMBIMIK-1 Ambisonic USB Microphone 32bit 192kHz ASIO Dirac
3%
The AmbiMIK-1 from MiniDSP is a FOA (First Order Ambisonic) ambisonic microphone with built-in preamplifier, analog-to-digital converter (ADC) and USB processor. This compact, portable solution provides high-resolution sound capture up to 32bit 192kHz. Suitable for Virtual Reality (VR), Augmented Reality (AR) or music recording applications, the AmbiMIK-1 does not require the use of an external preamplifier or XLR cables. A simple USB cable connects the microphone to a computer or tablet.
Reduced price!
Reference : 14588
Limited time offer:
559,00 €tax incl.
-3%
542,23 €tax incl.
451,86 € tax excl.
Shipping date: 06-05-2025.
MiniDSP AmbiMIK-1
MiniDSP AmbiMIK-1 Microphone Ambisonique USB 32bit 192kHz ASIO Dirac
With 4 low noise 14mm low noise capsules, a thin Aluminium body and a Nylon protective cover, the AmbiMIK-1 has been designed and engineered to offer excellent durability and performance at an affordable price. In addition, MiniDSP has worked with Dirac Research to develop a VST plugin calibrated specifically for the AmbiMIK-1 using more than 1200 measurements. The controls allow to act on the Yaw, Pitch and Roll parameters, as well as on the output gain or the output format (B or Binaural format).
Technical Characteristics
Product typeAmbisonic Microphone (FOA)
ConnectivityUSB 2.0
Sampling rate : up to 32bit 192kHz
USB ControllerXMOS 500MHz multicore processor
Integrated preamplifier
ADCADC 32bit with integrated PGA for analogic gain up to 60dB
SNR : 120dB
Gain control via Mac / Windows app
Capsules4x Low noise cardioid capsules, 14mm pre-polarized condenser
Max SPL : 127dB SPL
Self Noise : 16dB SPL
Format Layout : Ch1 - Front Left Up (FLU), Ch2 - Front Right Down (FRD), Ch3 - Back Left Down (BLD), Cha4 - Back Right Up (BRU)
SoftwareVST Plugin (Mac/Win) by Dirac Research specifically calibrated for AmbiMIK-1
Switchable output: B Format or Binaural
Controls : Output gain, Yaw, Pitch, Roll
USB AudioLinux / OSX / Android driverless
ASIO compatible driver for Windows
iOS support via USB Camera Kit
Body materialAluminium
ColorGray
Dimensions42 x 213mm
Weight130g
Package1x MiniDSP AmbiMIK-1
1x Tripod with microphone clamp
1x Wind screen
1x USB cable 2m
The AmbiMIK-1 from MiniDSP is a FOA (First Order Ambisonic) ambisonic microphone with built-in preamplifier, analog-to-digital converter (ADC) and...
