TONEWINNER ETM-2 Omnidirectional Measurement Microphone for Home Theater Calibration
The Tonewinner ETM-2 measuring microphone is designed to allow you, in association with certain Tonewinner home theater equipment, to automatically correct the acoustics of your system. It is connected to the AT-2300, AT-2000, AT-300 and AD-7300HD models and applies, according to the reproduction of your speakers, an optimal equalization for a perfect immersion and sound coherence.
4.0 / 5
Reference : 17353
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 13-05-2026.
Tonewinner ETM-2
Tonewinner ETM-2 Microphone de mesure pour calibrage Home Cinéma
How to use the microphone :
  1. Adjust the volume level of the amplifier to about 70%.
  2. Connect the microphone to the amplifier via the connector provided.
  3. Place the microphone in the most appropriate listening position.
  4. Keep the room quiet and avoid any movement during the measurement process. This may take 1 to 3 minutes depending on the number of speakers.
  5. From the interface of your device, go to the following menu: Menu → Acoustic Test → Auto Room Test.
  6. When the measurement process ends, press the "Apply" button to save the configuration.
  7. You can now disconnect your microphone.
Product typeMeasuring microphone
CompatibilityTonewinner AT-2300
Tonewinner AT-2000
Tonewinner AT-300
Tonewinner AD-7300HD
Sensitivity-40dB
DirectivityOmnidirectional
Microphone connectorXLR
Cable connectorJack 3.5mm
Cable length5m
InputNC
OutputNC
Max sampling rateNC
Fait son taff...
...mais le jack n est pas du 6.35 comme indiqué dans la description technique mais du 3.5...comme sur les photos. Fonctionne aussi avec un AD-7200HD si l on a un adaptateur jack 3.5/6.35 .
Sinon article expédié rapiidement en emballages cartons bien calé par du papier. Merci Audiophonics
This review has been posted for TONEWINNER ETM-2 Omnidirectional Measurement Microphone for Home Theater Calibration
The Tonewinner ETM-2 measuring microphone is designed to allow you, in association with certain Tonewinner home theater equipment, to automatically...
