DAYTON AUDIO DMA58-4 Speaker Driver Full Range Dual Magnet 15W 4 Ohm 86.2dB 160Hz-20kHz Ø50.8mm
Delivering high efficiency and low distortion, the Dayton Audio DMA58-4 is an ideal full-range driver for a modern compact speaker design. Its motor uses two neodymium magnets to create a strong and symmetrical magnetic field for perfect diaphragm control.
Reference : 17209
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 03-04-2026.
Grantie 5 ans
Dayton Audio DMA58-4 Haut-Parleur Large Bande Double Aimant 15W 4 Ohm 86.2dB 160Hz-20kHz Ø50.8mm
Delivering high efficiency and low distortion, the Dayton Audio DMA58-4 is an ideal full-range driver for a modern compact speaker design. Its motor uses two neodymium magnets to create a strong and symmetrical magnetic field for perfect diaphragm control. The careful design of the DMA58-4 also reduces inductance and distortion, improving high-frequency response. The double-layer voice coil is wound on a widely ventilated aluminum support, allowing for excellent heat dissipation, power handling and low compression. The aluminum diaphragm is held in place by a rubber suspension and a large basket, providing excellent mechanical damping.
Driver typeFull range
Nominal diameterØ50.8mm (2")
Power handlingRMS : 15W
Max : 30W
Impedance4Ω
Frequency response160Hz - 20kHz
Sensitivity86.2dB 2.83V/1m
Voicec coil diameterØ25.4mm (1")
Weight159g
Thiele-Small parameters
Resonant frequency (fS)165.5Hz
DC resistance (RE)3.55Ω
Electrical quality factor (QES)0.56
Mechanical quality factor (QMS)2.4
Total quality factor (QTS)0.46
Compliance equivalent volume (VAS)0.141L (0.005ft³)
Voice coil inductance (LE)0.2mH
Force factor (B·l)3.67T·m
Mechanical compliance of suspension (CMS)0.45mm/N
Surface area of cone (SD)14.5cm²
Maximum linear excursion (Xmax)±2mm
Materials
Cone materialAluminum
Surround materialRubber
Voice coil wire materialCopper
Voice coil former materialAluminum
Frame materialPolymer
Magnet materialNeodymium
Mounting informations
Overall outside dimensions56*56mm
Cutout diameterØ49.8mm
Total depth31.75mm
Bolt circle diameterØ64.3mm
Number of mountin holes4
Optimum cabinet size
Sealed volume0.57L (0.02ft³)
Sealed F3310Hz
Vented volume0.57L (0.02ft³
Vented F394Hz
Speaker Power (W RMS)15.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)51.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)160
Highest frequency (Hz)20000
Delivering high efficiency and low distortion, the Dayton Audio DMA58-4 is an ideal full-range driver for a modern compact speaker design. Its...
