With the PC105-4, Dayton Audio unveils a full-range speaker driver with a compact form factor and 40Wrms power handling. This speaker delivers smooth, natural sound reproduction. It is ideal for DIY construction or repair of small audio systems, or as a building block for more complex assemblies requiring several drivers of the same type. Despite its small size, the PC105-4 4" delivers good sound reproduction and is suitable for a wide range of uses. It performs well when used as a midrange driver in a three-speaker system. It can also be used in the design/repair of portable speakers, line arrays, soundbars or any other configuration requiring speaker networking.
Here are some of the highlights of the Dayton Audio PC105-4:
Product type | Full-range speaker driver |
Power handling | 40Wrms 80W max. |
Impedance | 4 ohm |
Frequency response | 80Hz-15kHz |
Sensibility | 90.3dB 2,.3V/1 m |
Nominal diameter | 10.16cm (4") |
Bolt Circle Diameter | 11.3cm (4.45") |
Voice coil diameter | 2.54cm (1") |
Depth | 5.99cm (2.36") |
Mounting holes | 4 |
thiele-small parameters | |
Resonant Frequency (Fs) | 81.4Hz |
DC resistance (Re) | 3.3 ohm |
Voice Coil Inductance (Le) | 0.32mH |
Mechanical Q (Qms) | 2.17 |
Electromagnetic Q (Qes) | 0.67 |
Total Q (Qts) | 0.51 |
Compliance Equivalent Volume (Vas) | 0.13ft³ |
Mechanical Compliance of Suspension (cms) | 0.92mm/N |
BL Product (BL) | 3.3T·m |
Diaphragm Mass Inc. Airload (Mms) | 4.2g |
Maximum Linear Excursion (Xmas) | 2mm |
Surface Area of Cone (Sd) | 52.8cm² |
Materials of construction | |
Cone Material | Poly-composite |
Surround Material | Caoutchouc |
Voice Coil Wire Material | CCA |
Voice Coil Former | Aluminium |
Basket / Frame Material | Acier |
Magnet Material | Ferrite |
Recommended enclosure volume | |
Sealed Volume | 0.07ft³ |
Sealed F3 | 136Hz |
Vented Volume | 0.15ft³ |
Vented F3 | 80Hz |
Package | 1x DAYTON AUDIO PC105-4 speaker driver |
Speaker Power (W RMS) | 40.0 |
Speaker Type | Full range |
Impedance (Ω) | 4 |
Loudspeaker diameter (mm) | 107.0 |
Diaphragm type | Composite alloy |
Efficiency / Sensitivity (dB) | 90.0 |
Max Linear Excursion (Xmax) (mm) | 2.0 |
Lowest frequency (Hz) | 80 |
Highest frequency (Hz) | 15000 |
