DAYTON AUDIO PS220-8 Speaker Driver Full Range Paper 40W 8 Ohm 96dB 40Hz - 25kHz Ø22cm
The Fountek PS220 full-range loudspeaker has the particularity of producing both bass and articulate, balanced midrange, as well as extended highs. The full-range concept eliminates the need for passive filtering (capacitors, chokes) for a highly musical sound. The loudspeakers in this range are thus capable of high sensitivity and smooth response.
4.0 / 5
By buying this product you get 23 loyalty points
Reference : 8244
235,00 €tax incl.
195,83 € tax excl.
Shipping date: 02-06-2026.
Grantie 5 ans
The Broadband SpeakerFountek PS220has the peculiarity of producing both bass, articulated and balanced midrange, as well as extended treble.
The concept of broadband allows passive filtering (capacitors, chokes) to be avoided for an audio rendering of great musicality.br>
The loudspeakers of this range are thus able to restore a high sensitivity and a gentle response.
SP220-8 Dayton Audio Documentation
SP220-8 Test and Tests
Specifications:
  • Nominal Power (RMS): 40 Watts
  • Nominal Power (Max): 80 Watts
  • Impedance: 8 ohms
  • Frequency response: 40 to 25,000 Hz.
  • Sensitivity: 95.6 dB 1W / 1m
  • Coil diameter: 2.5cm
  • Resonant Frequency (Fs): 45.5 Hz
  • Resistance DC (Re): 6.0 ohms
  • Inductance Voice Coil (Le): 0.75 mH
  • Q Mechanical (QMS): 3.61
  • Q electromagnetic (Qes): 0.32
  • Q total (Qts): 0.30
  • Equivalent volume of compliance (Vas): 2.79 m³
  • Mechanical suspension compliance (Cms): 1.15 mm / N
  • BL Product (BL): 7.5 Tm
  • Diaphragm Mass Inc. Airload (MMS): 10.6g
  • Max. Linear travel (Xmax): 4.8 mm
  • Surface of cone (Sd): 216,4 cm ²
  • Cone Material: Paper / Kevlar
  • Coil: Aluminum
  • Overall outside diameter: 22cm
  • Depth: 9cm
https://www.audiophonics.fr/images2/8244/8244_daytonaudio_PS220-8_hautparleur_1.jpg
https://www.audiophonics.fr/images2/8244/8244_daytonaudio_PS220-8_hautparleur_2.jpg
https://www.audiophonics.fr/images2/8244/8244_daytonaudio_PS220-8_hautparleur_3.jpg
https://www.audiophonics.fr/images2/8244/8244_daytonaudio_PS220-8_hautparleur_4.jpg
https://www.audiophonics.fr/images2/8244/8244_daytonaudio_PS220-8_hautparleur_5.jpg
https://www.audiophonics.fr/images2/8244/8244_daytonaudio_PS220-8_hautparleur_6.jpg
https://www.audiophonics.fr/images2/8244/8244_daytonaudio_PS220-8_hautparleur_7.jpg
https://www.audiophonics.fr/images2/8244/8244_daytonaudio_PS220-8_hautparleur_8.jpg
https://www.audiophonics.fr/images2/8244/8244_daytonaudio_PS220-8_hautparleur_9.jpg
Speaker Power (W RMS)40.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)220.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)96.0
Max Linear Excursion (Xmax) (mm)4.8
Lowest frequency (Hz)40
Highest frequency (Hz)25000
belle surprise
achetai pour une 2 vois DIY se dayton ps 220 et une alternative intéressante à une compression 1.4 pouce !
le but étant de concevoir une enceintes simple en 2 vois avec le moins de composant possible .
grave 38 cm 18 sound
medium & haute fréquences dayton audio ps 220
coupure 380 / 12 db grave 6 DB large bande .
volume grave 160 litres bass reflex volume ps 220 25 litres clos .
autre large bande en ma possessions ( pour comparé au dayton ps 220 )
fostex fe 206 médium plus chaleureux mai plus compliquer à mètre en ouvre sonorité asses marquer .
supravox 215 version sans bicone !! médium bien en place sonorité naturel nécessite un tweeter ou un moteur 1 pouce !!
dayton audio ps 220 médium naturel bien en places un vrais large bande capable de travailler sans tweeter !! je le mesure jusque à 20 000 hz chez moi !! je le qualifierai de polyvalent même si je considère qu'il et presque indispensable de rajouter un renfort de grave comme moi avec un 38 cm à haut rendement pour relevé la coube en bas . ou l'utiliser tout seul avec un filtre bouchon et indispensable pour atténuer la monter de la courbe ! pour ma part je préfère l'option n 1 avec un 38 cm .
bref pour conclure se large bande et une belle surprise sa construction et sérieuse et de qualité la mesure et vraiment propre et il à rien à envier à un 215 ou fe 206 de fostex !!
le medium et propre en place rien et mie en avant ont peu se passer sans problème de tweeter au final se large bande me permet de construire une enceintes simple et vraiment audiophile à haut rendement avec un prix contenue !!
 (4)
This review has been posted for DAYTON AUDIO PS220-8 Speaker Driver Full Range Paper 40W 8 Ohm 96dB 40Hz - 25kHz Ø22cm
The Fountek PS220 full-range loudspeaker has the particularity of producing both bass and articulate, balanced midrange, as well as extended highs....
