HiVi SWANS B2S Speaker Driver Full Range Aluminium Shielded 10W 8 Ohm 78dB 150Hz - 15kHz Ø5.1cm
Reference : 4805
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 01-07-2025.
https://www.audiophonics.fr/images2/Swans_Logo.gif
Broadband loudspeaker, ideal for creating a multimedia or home cinema system that combines compactness and performance.
Can also be used as a Medium speaker in a multi-channel configuration.
Ultra rigid cone made up of aluminum and magnesium alloy coated on the surface with a damping material promoting dynamic stability
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Magnetic motor neodymium
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
https://www.audiophonics.fr/images2/4805_SWANS-HIVI-B2S_1.jpghttps://www.audiophonics.fr/images2/4805_SWANS-HIVI-B2S_2.jpg
https://www.audiophonics.fr/images2/4805_SWANS-HIVI-B2S_3.jpg
Specifications:
  • Nominal Impedance:8Ω
  • Resonant Frequency: 152Hz
  • Rated Power:10W
  • Sensitivity (2.83v / 1m): 78dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 25mm
  • Length Coil:6mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: Ferrite
  • Magnetic Shielding:/ Strong>Yes
  • BL:2.5
  • Hey :3.0mm
  • XmaX:1.5mm
  • Cms:689
  • Qms:5.69
  • Qes:1.53
  • Qts:1.20
  • Mms:1.60g
  • Sd:0.0013m2
  • Vas:0.2L
  • Recommended Type of Load: Close
  • Recommended Load Volume: 0.2L
  • Recommended Cut-Off Frequency -3dB: 149Hz
  • Weight:0.12kg
https://www.audiophonics.fr/images2/HiVi_Logo.jpg
https://www.audiophonics.fr/images2/4805_SWANS-HIVI-B2S_4.jpg
HiVi B2S:Dimensions
https://www.audiophonics.fr/images2/4805_SWANS-HIVI-B2S_5.jpg
HiVi B2S:Frequency Response
https://www.audiophonics.fr/images2/4805_SWANS-HIVI-B2S_6.jpg
HiVi B2S:Impedance Curve
Speaker Power (W RMS)10.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)51.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)78.0
Max Linear Excursion (Xmax) (mm)1.5
Lowest frequency (Hz)150
Highest frequency (Hz)15000
