HiVi's "F" loudspeaker range is a synthesis of all the technological advances made in the last few years in the field of electroacoustics.
It is also the expression of the extraordinary know-how of a team of engineers and music lovers resolutely in the forefront.
Ultra rigid cone from a learned combination of Kevlar and paper
Peripheral suspension in natural rubberGerman-made loudspeaker system that provides long-lasting loudspeaker performance and absorbing parasitic vibrationsoriginating at the surface of the cone
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor consisting of 2 magnets mounted in symmetrical and ventilated
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
Can be used as a severe / medium unit on a 2-way system ,or as a medium loudspeaker on a 3-way system more sophisticated.
Specifications:
HiVi F5:Dimensions
HiVi F5:Frequency Response
HiVi F5:Impedance Curve
Speaker Power (W RMS) | 35.0 |
Speaker Type | Midbass |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 127.0 |
Diaphragm type | Kevlar |
Efficiency / Sensitivity (dB) | 86.0 |
Max Linear Excursion (Xmax) (mm) | 2.7 |
