The Monacor SPX-200WP full-range driver offers excellent sound quality, with a wide frequency response. It reveals a very slight accentuation in the high frequencies, with nevertheless deep bass reproduction. It features a low-resonance polypropylene cone and rubber suspension. Ideal for installation in a load-closed cabinet.
Speaker driver type | Full range |
Nominal diameter | Ø203mm |
Power handling | RMS : 50W Max : 400W |
Impedance | 8Ω |
Frequency response | 36Hz - 18000Hz |
Sensitivity | 89dB |
Voice coil diameter | Ø25mm |
Weight | 1.32kg |
Total external dimensions | Ø203*89mm |
Magnet weight | 564g |
Thiele-Small parameters | |
Resonant frequency (fS) | 36Hz |
DC resistance (RE) | 7.6Ω |
Voice coil inductance (LE) | 0.35mH |
Mechanical quality factor (QMS) | 4.18 |
Electrical quality factor (QES) | 0.69 |
Total quality factor (QTS) | 0.59 |
Equivalent volume to the compliance (VAS) | 60.5L |
Compliance (CMS) | 950µm/N |
force factor (B·l) | 6.79T·m |
Mechanical resistance (RMS) | 1.07N·s/m |
Moving mass (MMS) | 19.7g |
Moving mass (without airload) (MMD) | 17.4g |
Max linear excursion (XMAX) | 2mm |
Air volume displaced at Xmax (VD) | 43cm³ |
Efficiency (η₀) | - |
Bandwidth efficiency (EBP) | - |
Effective area (SD) | 213cm² |
Materials | |
Diaphragm | Polypropylene |
Surround | Rubber |
Voice coil wire | Kapton |
Voice coil former | - |
Frame | - |
Magnet | - |
Mounting informations | |
Outer diameter | Ø203mm |
Cutout diameter | Ø180mm |
Depth | 89mm |
Bolt circle diameter | - |
Number of mounting holes | 4 |
Speaker Power (W RMS) | 50.0 |
Speaker Type | Full range |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 203.0 |
Diaphragm type | Polypropylene |
Efficiency / Sensitivity (dB) | 89.0 |
Max Linear Excursion (Xmax) (mm) | 2.0 |
Lowest frequency (Hz) | 36 |
Highest frequency (Hz) | 18000 |
