SUPRAVOX 400-2000 Speaker Driver Full Range 120W 8 Ohm 96dB 24Hz - 4000Hz Ø 40cm
Supravox 400-2000 (GN-B) - 40 cm - 96 dB - 24 Hz / 4 kHz
By buying this product you get 123 loyalty points
Reference : 41
1 230,00 €tax incl.
1 025,00 € tax excl.
Shipping from France
Billing in France
Technical support in France
This high-performance (96 dB) bass speaker offers you a fast, deep and very pleasant listening.
Its exponential membrane ensures a wide bandwidth with a natural cut-off at 4000 Hz without accidents at the end of the band. Its engine made up of a ring of 3.5 Kg in Alnico makes it possible to obtain the field
necessary to achieve such sensitivity.
These qualities allow it to be directly coupled with a 1-inch engine mounted on our roof.
Mounted in a bassreflex or jensen box, cut at 500Hz, the response curve will be straight to ± 2 dB up to the final frequency of the 1-inch motor.
Sensitivity 1 W / 1m to Fs96 dBfs23 Hz
Impedance8 ohmsRe6.5 ohms
Bandwidth24 to 4kHzqt0.27
Power Max. RMS120 WQe0.28
Weight10.7 kgQm9
SuspensionCanvasVas450
Linear Excursion10 mmbl14.5
Alnico Magnet3.5 kgcms
0.6
Magnetic field1.6 Tmms70 g
HP Diameter404 mmsd
855 cm²
Speaker Power (W RMS)120.0
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)400.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)96.0
Max Linear Excursion (Xmax) (mm)10.0
Lowest frequency (Hz)24
Highest frequency (Hz)4000
