Tectonic's BMR range consists of full-range speakers designed to cover a very wide part of the audible spectrum. For example, the TEBM65C20F-4 features an extended frequency response from 60Hz to 20kHz, as well as wide directivity. Furthermore, Tectonic combines flexible wave technology and a piston mode of operation to ensure high audio performance despite a very small speaker format.
Product type | Full-range loudspeaker |
Nominal diameter | 7.6cm (3-1/2") |
Power Handling (RMS) | 30W |
Power Handling (MAX) | 60W |
Impedance | 4 ohm |
Frequency Response | 60Hz-20kHz |
Sensitivity | 81dB 2.83V/1m |
Voice Coil Diameter | 2.54cm (1") |
Thiele-small parameters | |
Resonant Frequency (Fs) | 97Hz |
DC Resistance (Re) | 3.8Ω |
Voice Coil Inductance (Le) | 0.03mH |
Mechanical Q (Qms) | 7 |
Electromagnetic Q (Qes) | 0.94 |
Total Q (Qts) | 0.83 |
Compliance Equivalent Volume (Vas) | 0.035ft³ |
Mechanical Compliance of Suspension (Cms) | 0.47mm/N |
BL Product (BL) | 3.75T·m |
Surface Area of Cone (Sd) | 37.2cm² |
Material | |
Cone Material | Paper |
Surround Material | Rubber |
Basket / Frame Material | Polymer |
Magnet Material | Ferrite |
Mounting information | |
Overall Outside Diameter | 10.16 (4.25") |
Baffle Cutout Diameter | 7.62cm (3.25") |
Depth | 5.08cm (2.125") |
# Mounting Holes | 6 |
Recommanded enclosure volume | |
Sealed Volume | 0.06ft³ |
Sealed F3 | 101.3Hz |
Vented Volume | 0.08ft³ |
Vented F3 | 75.1Hz |
Général | |
Weight | 1.65kg |
Package | 1x Haut-parleur large bande Tectonic TEBM65C20F-4 |
Speaker Power (W RMS) | 30 |
Speaker Type | Full range |
Impedance (Ω) | 4 |
Loudspeaker diameter (mm) | 76.0 |
Diaphragm type | Paper |
Efficiency / Sensitivity (dB) | 81.0 |
Max Linear Excursion (Xmax) (mm) | 10.0 |
Lowest frequency (Hz) | 60 |
Highest frequency (Hz) | 20000 |
