VISATON K 50 WP Speaker Driver Full Range 2W 8 Ohm 84dB 180Hz-17kHz Ø5cm
The Visaton K 50 WP is a small full range loudspeaker with a diameter of 5cm, with a plastic frame and diaphragm. It offers a wide frequency response and a beautiful sound reproduction. It is particularly suitable for use outdoors or in humid areas.
Reference : 16611
7,50 €tax incl.
6,25 € tax excl.
Shipping date: 19-06-2025.
Visaton K 50 WP
Speaker Driver Full Range 2W 8Ω 84dB 180Hz-17kHz Ø5cm
Visaton K 50 WP Haut-Parleur Large Bande 2W 8Ω 84dB 180Hz-17kHz Ø5cm
Visaton K 50 WP Haut-Parleur Large Bande 2W 8Ω 84dB 180Hz-17kHz Ø5cm Visaton K 50 WP Haut-Parleur Large Bande 2W 8Ω 84dB 180Hz-17kHz Ø5cm Visaton K 50 WP Haut-Parleur Large Bande 2W 8Ω 84dB 180Hz-17kHz Ø5cm
Product typeSpeaker driver
Speaker driver typeFull range
Handling powerRMS : 2W
Max : 3W
Impedance8Ω
Diaphragm materialMylar
Basket materialABS
Frequency response180Hz - 17kHz
SPL84dB (1W/1m)
Linear excursion±1mm
Resonant frequency300Hz
Front panel thickness2mm
Voice coil diameterØ10mm
Winding height2.5mm
Cutout diameterØ46mm
Weight48g
Speaker Power (W RMS)2.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)50.0
Diaphragm typePlastic
Efficiency / Sensitivity (dB)84.0
Max Linear Excursion (Xmax) (mm)1.0
Lowest frequency (Hz)180
Highest frequency (Hz)17000
The Visaton K 50 WP is a small full range loudspeaker with a diameter of 5cm, with a plastic frame and diaphragm. It offers a wide frequency...
