E1DA 9038S GEN 3 Balanced Headphone Amplifier USB DAC ES9038Q2M AD8397 32bit 384kHz DSD256
The 9038SG3 from E1DA is a high performance USB DAC and portable symmetrical headphone amplifier combo. Compact and lightweight, it nevertheless incorporates excellent components to ensure excellent sound reproduction, marked by incredible precision and richness.
4.9 / 5
Reference : 14638
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 03-11-2026.
E1DA 9038S Gen 3
DAC USB Amplificateur Casque Symétrique ES9038Q2M AD8397
E1DA 9038SG3 DAC USB Amplificateur Casque Symétrique ES9038Q2M AD8397
For example, its aluminium shell conceals a DAC ES9038Q2M chip supporting high sample rates up to 32bit 384kHz PCM and DSD256. The 9038SG3 works without battery and is powered directly by your playback device (smartphone, DAP...) but offers a particularly low power consumption. The input is on USB-C connector where the output is on a balanced 2.5mm jack plug (pinout Astell & Kern). The USB interface chip is a ComTrue CT7601 with 100% proprietary code to maximize Android and DSD compatibility.
The instrument's measurements are particularly good, with a wide frequency response from 10Hz to 100kHz, an SNR of -123dBA, a dynamic range of 123dBA, or a THD of only 0.0002% (@ 32Ω, 1kHz, -3dBFS). Under these circumstances, the distortion is almost indistinguishable from electronic noise.
Pinout Balanced Jack 2.5mm (Astell & Kern)
E1DA Tweak9038 App
E1DA's Tweak9038 application allows you to control harmonic distortion compensation, select a Nyquist filter, manage the Master Clock frequency and much more. Most of the parameters can be set dynamically depending on the hardware volume, audio data rate, etc. An ideal tool to adapt the sound reproduction of your DAC according to your listening and your hardware.
Application E1DA Tweak9038 Android
It is not possible and strongly discouraged to use a balanced to unbalanced adapter with the 9038SG3. This could damage it irreparably.
E1DA 9038S Gen 3 review by Audio Science Review
" ... inside lives a potent, highly optimized DAC and efficient headphone amplifier. It shows excellent command of engineering and proper design verification through measurements. "
Test du E1DA 9038S Gen 3 par Audio Science Review
Product typeUSB DAC
Balanced headphone amplifier
InputUSB-C
OutputBalanced Jack 2.5mm (pinout Astell & Kern)
Note: Never use an unbalanced adapter, it can seriously damage the DAC.
DAC ChipES9038Q2M
Amplification chipAD8397
DSD up to DSD256
Output impedance100mΩ
Output power> 340mW @ 32Ω, 1kHz, THD=1%
> 550mW @ 16Ω, 1kHz, THD=1%
Frequency response10Hz - 100kHz (+0.1/-0.3dB)
SNR-123dB(A)
Dynamic range AES17123dB(A)
THD0.0002% @ 32Ω, 1kHz, -3dBFS
THD+N< 0.0002% @ 32Ω, -3dBFS
Crosstalk-126dB @ 1kHz 32Ω
Power supply5V via USB
Housing materialAnodized Aluminium
Dimensions48 x 22 x 9mm
Weight10g
A-A FFT Spectrum Analysis : -0.3dBFS, No load
A-A FFT Spectrum Analysis : -3dBFS, 32Ω
A-A FFT Spectrum Analysis : -6dBFS, 32Ω
A-A FFT Spectrum Analysis : -10dBFS, 32Ω
A-A FFT Spectrum Analysis : -20dBFS, 32Ω
Frequency response : PCM 32bit 384kHz
Output impedance 1mΩ 1µV
Crosstalk -126dB @ 1kHz 32Ω
Dynamic range AES17 32bit 384kHz 123dB(A)
SNR 123dB(A)
THD-N
No load = Blue curve
32Ω = Red curve
OutputJack 2.5mm
DAC / ADC ChipES9038Q2M
Max sampling rate384kHz
Max sampling rateDSD256
8 reviews
Achat E1DA 9038S GEN 3
Toujours aussi efficace, commande livrée rapidement et plein de bons conseils.
Le E1DA 9038S GEN 3 est vraiment bon, super qualité.
This review has been posted for E1DA 9038S GEN 3 Balanced Headphone Amplifier USB DAC ES9038Q2M AD8397 32bit 384kHz DSD256
a very small big sounding dac
The dac sounds very good, neutral and balanced. Love to listen to music. I use it with my iPhone SE 2022. There are two problems: 1. the cable between iPhone and dac has to be a special one, you need carefully chose an otg cable. 2. I did buy that cable in the shop of E1DA but it's very vulnerable when you use it during traveling and having the phone in you pocket. It's not special related to this product but making your audio portable by Phone, bend cable and dac.
does not fit some bright headphones/iems.
unsuitable for high-impedance headphones. 100 ohm and more.
Whhaaaouh !!!
Je voulais un casque nomade mais très bon.
On me conseille le Mezze néo 99. Celui en bois est très beau mais son frère jumeau sans bois coûte 100€ de moins. J'opte pour celui-là.
Audiophonics me demande si j'ai ce qu'il faut pour un casque symétrique (je reçois un cours sur la symétrisation). Non.
Ce casque peut se brancher via un cordon asymétrique (câble habituel) mais c'est un autre monde avec un câble symétrique (40€ de +). Vraiment ?
Les conseils de la boutique ayant toujours été bons, je dis ""OK, avec ce câble alors !
Mais votre smartphone sort-il en symétrique ? Non.
Alors si vraiment vous voulez passer de deux écouteurs sur les oreilles à une écoute immergée dans une salle de concert, il vous faut un E1DA (129€ de +). Un mini DAC-ampli de haute volée.
J'ai envie de me faire plaisir et je fais l'achat, je pars en voyage et sans musique, c'est pas possible.
Je mets le casque Mezze avec le câble standard. C'est très bon. Le casque est super agréable sur la tête, le son est bon. Il ne tien t pas chaud. Super.
Quid du E1DA du coup !? Je branche tout ça. Whhaaaouh !!
Ce n'est pas mieux, c'est un autre monde.
Je n'ai rien sur mes oreilles, je suis effectivement dans la salle de concert. Je situe les instruments, et les musiciens jouent pour moi. Tout y passe, classique, Jazz Rock, boum boum ... Génial.
J'ai parfois l'impression que je vais déranger mon épouse qui dort. Non. Tout est pour moi, rien pour ceux qui sont à côté.
Je ne regrette pas une seconde mon achat.
 (3)
Exceptionnel
Ce DAC est une merveille ! Combiné à mon Meze 99 Classics Noyer Gold équipé d'un câble symétrique, j'obtiens une restitution sonore de mes fichiers Qobuz on ne peut meilleure. C'est la perfection absolue. Mais je voudrais surtout souligner l'accompagnement technique que m'a fourni Audiophonics pour m'aider dans mon choix (Salut David). Je n'ai jamais rencontré un service technique aussi avisé, consciencieux, patient, réactif et compétant ailleurs. De plus, sitôt commandé, aussitôt expédié. Livré en Belgique en un temps record. À défaut de pouvoir mettre mille étoiles, j'adresse mille mercis à Audiophonics.
The 9038SG3 from E1DA is a high performance USB DAC and portable symmetrical headphone amplifier combo. Compact and lightweight, it nevertheless...
