EVOARIA EVO ERA CD Player DAC Headphone Amplifier
New
The Evoaria Evo Era is an all-in-one CD player integrating a DAC and a headphone amplifier. It combines two conversion architectures, Delta-Sigma with dual ES9069Q DACs and discrete R-2R, with three analog signatures, including two hybrid modes using KORG Nutube 6P1 tubes. This design makes it possible to adapt the conversion and sonic character to listening preferences, while bringing together physical playback and digital sources in a single device.
By buying this product you get 164 loyalty points
Reference : 22770
1 649,00 €tax incl.
1 374,17 € tax excl.
EvoAria Evo Era CD Player DAC Headphone Amplifier R2R 2xES9069Q 32bit 768kHz DSD512
EVOARIA EVO ERA: Front view
The EvoAria Evo Era is an all-in-one CD player integrating a DAC and a headphone amplifier. It combines two conversion architectures, Delta-Sigma with dual ES9069Q DACs and discrete R-2R, with three analog signatures, including two hybrid modes using KORG Nutube 6P1 tubes. This design makes it possible to adapt the conversion and sonic character to listening preferences, while bringing together physical playback and digital sources in a single device.
Designed for headphone listening as well as integration into an audio system, it combines CD playback, a high-resolution USB DAC, Bluetooth, and analog and digital outputs. Its built-in 10000mAh battery also allows use without mains power, while its settings, accessible directly on the device, make it easy to adapt to different headphones and sources.
EvoAria Evo Era: Two DAC architectures, two approaches to conversion
The EvoAria Evo Era combines two independent digital-to-analog conversion systems, letting you choose the architecture suited to the source and to your listening preferences. The Delta-Sigma mode is based on two ES9069Q DACs, each operating in mono within a fully differential architecture. This configuration aims for precise conversion, a wide dynamic range and the reproduction of low-level details.
The second mode relies on a discrete two-channel String R-2R network, made up of more than 170 precision resistors spread across four specifications. Each channel has its own independent power supply, while the OS mode, with oversampling, and NOS mode, without oversampling, allow the digital processing to be adapted. The choice between Delta-Sigma and R-2R, then between OS and NOS for the latter, gives access to several conversion configurations without changing device.
EVOARIA EVO ERA: DAC chips
EVOARIA EVO ERA: Amplification tubes
EvoAria Evo Era: Three sound signatures, including two with tubes
The analog circuit of the Evo Era takes up the architecture of the Evo One player in a format combining a CD player, DAC and headphone amplifier. It offers two hybrid tube signatures, Velvet and Lumina, as well as a fully solid-state mode. These settings modify the analog signal path and make it possible to adapt the reproduction to the headphones, the music or listening preferences.
The Velvet and Lumina modes rely on a pair of KORG Nutube 6P1 tubes and on a hybrid architecture combining buffer stages, tube voltage gain and a buffered driver stage. An independent JFET constant current source, integrated into the source load, contributes to the drive capability and control of the circuit. Velvet favors a warm presentation, with harmonic richness and a marked presence of even-order harmonics; this orientation is particularly suited to vocals and relaxed listening. Lumina aims for a clearer, more transparent reproduction, with strong definition and a harmonic balance designed to suit a variety of musical styles.
In FULLY TR mode, the signal bypasses the Nutube stage and passes through a fully discrete transistor amplification circuit. This path favors clarity, speed and control, while offering an alternative to the two hybrid signatures.
EvoAria Evo Era: Balanced headphone amplification
The headphone stage consists of four fully balanced channels, combining operational amplifiers and discrete power transistors. This architecture aims to maintain a low noise floor, good transient response and a power reserve suited to different headphones. The gain and power settings allow operation to be adjusted to the sensitivity and impedance of the headphones, as well as to the desired listening level.
With a compatible USB Power Delivery external power supply, the Evo Era can reach a rated power of 1500mW on the 4.4mm jack balanced output into 32Ω, in DC INPUT mode. The device is then powered directly by the external source, allowing its full headphone power to be used. Its rated specifications also include a dynamic range of 124dB, a signal-to-noise ratio of 125dB, a THD+N of 0.0025% and an output impedance of 1Ω.
EVOARIA EVO ERA: Transistor
EvoAria Evo Era: A CD player at the heart of a complete listening system
The Evo Era combines CD playback, USB conversion and Bluetooth reception in a single device. It can thus be used to listen to a disc collection, a digital library or music streamed from a compatible device, without imposing a single source or listening mode. The headphone outputs allow direct listening, while the line and digital outputs make it easy to integrate into a system including active speakers, a preamplifier, a headphone amplifier or an external DAC.
The custom CD mechanism and its dedicated servo system handle disc playback. Top loading keeps direct access to the tray: the magnetically closing lid opens to insert the disc, then closes before playback. The physical controls and the display give access to track selection, playback modes and time information, preserving straightforward operation without having to browse menus for everyday operations.
The Evo Era also allows CDs to be ripped to a compatible USB storage device. The CD RIP function records the music as lossless WAV files, so albums can be kept on digital media and played later on other compatible devices.
EvoAria Evo Era: High-resolution USB DAC and Bluetooth playback
Connected via USB to a compatible computer or smartphone, the Evo Era operates as an external DAC for locally stored files or streaming services. The Delta-Sigma and R-2R architectures, analog signatures and headphone amplification remain available, offering the same reproduction choices as in CD playback.
The XMOS XU316 USB processor supports the USB Audio Class 1.0 and 2.0 standards, with playback up to PCM 768kHz and DSD512. Over Bluetooth, the Qualcomm QCC5181 chip and Bluetooth 5.4 support Snapdragon Sound as well as the aptX Adaptive, aptX Lossless, aptX HD, LDAC, AAC and SBC codecs. With a compatible source and codec, wireless transmission can reach 24 bits 96kHz; however, codec availability and effective resolution depend on the transmitting device and the codec used.
EVOARIA EVO ERA: Bluetooth chip
EVOARIA EVO ERA: Front panel controls
EvoAria Evo Era: Settings accessible directly on the device
The Evo Era favors hardware control: dedicated switches and controls give access to the DAC mode, the analog signature, the gain and the amplifier power mode. The DAC selector switches between Delta-Sigma, R-2R OS and R-2R NOS; the analog circuit can be set to TR, Velvet or Lumina. Three gain levels, H, M and L, and the P, P+ and TURBO amplification modes complete these settings, to adapt the device to the connected headphones and the intended use.
The metal volume knob, finely knurled for a stable grip, combines an ALPS potentiometer with the NJW1195A volume control circuit. The 2.2-inch TFT display shows the track number, playback time, transport status and device information. Separate buttons control play, pause, stop and track change, while source selection and sound adjustment functions remain accessible through their dedicated controls.
EvoAria Evo Era: Analog and digital connectivity
The 3.5mm jack single-ended and 4.4mm jack balanced headphone outputs allow direct listening with different types of cables and headphones. The Evo Era also offers 3.5mm jack and 4.4mm jack balanced analog line outputs, as well as coaxial and optical digital outputs. This connectivity allows it to switch from a standalone headphone amplifier role to that of a source for active speakers or another component of the audio system.
Smart connection detection on the 3.5mm and 4.4mm analog outputs simplifies everyday use. The device can thus sit at the heart of a personal listening system or integrate into a larger setup, depending on the equipment already in place.
EVOARIA EVO ERA: Headphone and coaxial output
EVOARIA EVO ERA: On the go
EvoAria Evo Era: Versatile use
The CNC-machined 6063 aluminum alloy chassis combines structural rigidity with a matte finish. Glass bead blasting with 200 grit provides an even texture, while the 29mm profile limits the footprint on a desk or in a listening space. The top opening of the CD compartment, the knurled knob and the physical controls extend this approach to the handling of the device.
The built-in 10000mAh battery allows listening without mains power, with a rated maximum battery life of 14 hours. A full charge via USB PD is rated at 3.5 hours. The supplied leather carrying case protects the chassis from scratches and minor everyday knocks; its shoulder strap makes it easy to carry, while the display, playback buttons and volume knob remain accessible with the case fitted.
Technical specifications
Product typeCD player
DAC
Headphone amplifier
Inputs1x USB-C
CD player
Bluetooth
Outputs1x Coaxial / Optical
1x 3.5mm Jack line single-ended output
1x 4.4mm Jack line balanced output
1x 3.5mm Jack single-ended headphone output
1x 4.4mm Jack balanced headphone output
DAC chip2x ES9069Q
R2R
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
USB interfaceXMOS XU316
Bluetooth chipQualcomm QCC5181
Supported Bluetooth codecsaptX Adaptive, aptX Lossless, aptX HD, LDAC, AAC, SBC
Battery10000mAh
3.5mm headphone jack output
Output power500mW @ 16Ω, P
600mW @ 16Ω, P+
710mW @ 16Ω, Turbo
850mW @ 16Ω, DC IN
310mW @ 32Ω, P
380mW @ 32Ω, P+
465mW @ 32Ω, Turbo
550mW @ 32Ω, DC IN
80mW @ 150Ω, P
98mW @ 150Ω, P+
117mW @ 150Ω, Turbo
120mW @ 150Ω, DC IN
Frequency response20Hz-52kHz @ Δ-Σ, Fully TR
20Hz-30kHz @ R2R OS, Fully TR
20Hz-27kHz @ R2R NOS, Fully TR
20Hz-45kHz @ Δ-Σ, Tube Lumina
20Hz-29kHz @ R2R OS, Tube Lumina
20Hz-26kHz @ R2R NOS, Tube Lumina
THD+N0.0025% @ Δ-Σ, Fully TR
0.0022% @ R2R OS, Fully TR
0.0025% @ R2R NOS, Fully TR
0.25% @ Δ-Σ, Tube Lumina
0.25% @ R2R OS, Tube Lumina
0.25% @ R2R NOS, Tube Lumina
Dynamic range121dB @ Δ-Σ, Fully TR
108dB @ R2R OS, Fully TR
107dB @ R2R NOS, Fully TR
119dB @ Δ-Σ, Tube Lumina
108dB @ R2R OS, Tube Lumina
107dB @ R2R NOS, Tube Lumina
SNR121dB @ Δ-Σ, Fully TR
118dB @ R2R OS, Fully TR
118dB @ R2R NOS, Fully TR
117dB @ R2R OS, Tube Lumina
117dB @ R2R NOS, Tube Lumina
Crosstalk72dB
Output impedance0.5Ω
4.4mm jack headphone output
Output power850mW @ 16Ω, P
1050mW @ 16Ω, P+
1240mW @ 16Ω, Turbo
1700mW @ 16Ω, DC IN
700mW @ 32Ω, P
880mW @ 32Ω, P+
1050mW @ 32Ω, Turbo
1500mW @ 32Ω, DC IN
210mW @ 150Ω, P
260mW @ 150Ω, P+
315mW @ 150Ω, Turbo
460mW @ 150Ω, DC IN
0.0024% @ R2R OS, Fully TR
0.0028% @ R2R NOS, Fully TR
Dynamic range124dB @ Δ-Σ, Fully TR
110dB @ R2R OS, Fully TR
118dB @ Δ-Σ, Tube Lumina
SNR125dB @ Δ-Σ, Fully TR
115dB @ R2R OS, Fully TR
115dB @ R2R NOS, Fully TR
113dB @ R2R OS, Tube Lumina
113dB @ R2R NOS, Tube Lumina
Crosstalk107dB @ Δ-Σ, Fully TR
103dB @ R2R OS, Fully TR
103dB @ R2R NOS, Fully TR
107dB @ Δ-Σ, Tube Lumina
102dB @ R2R OS, Tube Lumina
102dB @ R2R NOS, Tube Lumina
Output impedance1Ω
3.5mm jack line output
Output level2.1V
Frequency response20Hz-60kHz @ Δ-Σ, Fully TR
20Hz-29kHz @ R2R NOS, Fully TR
20Hz-50kHz @ Δ-Σ, Tube Lumina
20Hz-30kHz @ R2R OS, Tube Lumina
20Hz-27kHz @ R2R NOS, Tube Lumina
THD+N0.0022% @ Δ-Σ, Fully TR
0.0028% @ R2R OS, Fully TR
0.0030% @ R2R NOS, Fully TR
107dB @ R2R OS, Fully TR
120dB @ Δ-Σ, Tube Lumina
107dB @ R2R OS, Tube Lumina
SNR123dB @ Δ-Σ, Fully TR
121dB @ R2R OS, Fully TR
121dB @ R2R NOS, Fully TR
119dB @ R2R OS, Tube Lumina
119dB @ R2R NOS, Tube Lumina
Crosstalk90dB
Output impedance100Ω
4.4mm jack line output
Output level4.2V
0.0023% @ R2R OS, Fully TR
0.0026% @ R2R NOS, Fully TR
Dynamic range125dB @ Δ-Σ, Fully TR
109dB @ R2R OS, Fully TR
108dB @ R2R NOS, Fully TR
121dB @ Δ-Σ, Tube Lumina
108dB @ R2R NOS, Tube Lumina
SNR126dB @ Δ-Σ, Fully TR
120dB @ R2R OS, Fully TR
120dB @ R2R NOS, Fully TR
122dB @ Δ-Σ, Tube Lumina
118dB @ R2R OS, Tube Lumina
118dB @ R2R NOS, Tube Lumina
Crosstalk105dB @ Δ-Σ, Fully TR
102dB @ R2R OS, Fully TR
102dB @ R2R NOS, Fully TR
103dB @ Δ-Σ, Tube Lumina
100dB @ R2R OS, Tube Lumina
100dB @ R2R NOS, Tube Lumina
Dimensions182 x 182 x 29mm
Weight1025g
ColorSilver and gold
Package1x EvoAria Evo Era
1x Leather case
1x USB-C to USB-C cable
EVOARIA EVO ERA CD Player DAC Headphone Amplifier R2R 2xES9069Q 32bit 768kHz DSD512
The Evoaria Evo Era is an all-in-one CD player integrating a DAC and a headphone amplifier. It combines two conversion architectures, Delta-Sigma...
