[GRADE S] SOMMERCABLE ELEPHANT SPM840 Cable OFC OFC 8x4.0mm² Ø 15.6mm 1m
-32%
Refurbished product - Grade S
1m long pre-cut cable
Reduced price!
Reference : 22799
18,90 €tax incl.
-32%
12,90 €tax incl.
10,75 € tax excl.
Last items in stock !
Shipping date: 01-12-2026.
Cable offcut with a length of 1m
SOMMER CABLE - SC-ELEPHANT ROBUST SPM840
We have further improved the cable stability of the 4.0 mm² EL seriesEphant. These cables are robust but flexible, resistant to crushing, easily rollable and support countless cycles of use. The surface of the outer sheath is even smoother and therefore easier to clean. The external diameters are also suitable for common multi-spindle speakers (CA-COM 8-pole, NL8, LKS 19, EP5), thus facilitating assembly or transformation.
Themodel ELEPHANT SPM1640 is very interesting: with it, just one cable to connect eight lines of speakers with the central network. You will also find many other remarkable solutions in the chapter "equipped cables".
ADVANTAGES:
  • Transmission of signals without loss, thanks to specially formed cores
  • Very flexible, suitable for stage installations, easily rollable
  • Compatible with 8-pin CA-COM connectors, NL8, LKS19, EP5
  • Easy transformation thanks to the excellent insulation and numbering of the cores
USE:
  • Professional Acoustic Equipment / Output Amplifier
Specifications:
Constitution(8LIY4.0mm2) Y
Envelope, diameter PVC 15.6 mm
AWG11
Number of Conductors8 x 4 mm2
Envelope material, insulation HM2 (C mode halogen-free) PVC
Brass Cu per core 128 x 0.20 mm
Conductor insulation, diameter 3.75 mm
Operating temperature
Operating temperaturemax. 70 ° C
Fire resistance per m0.94 kWh
Weight per m550 g
Color of envelopeblack
Length1m
Electrical Specifications:
Odometer Resistance, Conductor<4.5 Ohm
Kilometer resistance, isolation> 5 MOhm
Operating voltagemax. 300 V
Test voltage2 kV
Diameter (mm)15.6
Length (m)1.0
Number of conductors8
Insulation materialPVC
ShieldingNo
Section (mm²)4.00
Refurbished GradeGrade S
Ground / ShieldingNo
Refurbished product - Grade S 1m long pre-cut cable
