FIIO BTR15 Balanced Headphone Amplifier Portable DAC
This FiiO BTR15 portable DAC headphone amplifier is a small, affordable device, but no less high-performance, since it integrates a number of market-renowned components: dual ES9219MQ DAC, QCC5125 Bluetooth receiver chip and XMOS XU316 USB interface. This high-quality chipset enables it to support high-resolution streams up to PCM 32bit 384kHz, DSD256 and MQA via its USB input.
Reference : 18895
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 17-07-2025.
FIIO BTR15Balanced Headphone Amplifier Portable DAC ES9219MQ Bluetooth LDAC 32bit 384kHz DSD256 MQA
FiiO BTR15 picture
This FiiO BTR15 portable DAC headphone amplifier is a small, affordable device, but no less high-performance, since it integrates a number of market-renowned components: dual ES9219MQ DAC, QCC5125 Bluetooth receiver chip and XMOS XU316 USB interface. This high-quality chipset enables it to support high-resolution streams up to PCM 32bit 384kHz, DSD256 and MQA via its USB-C input. In addition, it features high-quality wireless connectivity thanks to its Qualcomm Bluetooth 5.1 receiver chip, which accepts numerous Bluetooth codecs: SBC, AAC, aptX, aptX LL, aptX Adaptive, aptX HD and LDAC. In terms of amplification, it features a balanced structure and two headphone outputs, one on a 3.5mm jack and one balanced on a 4.4mm jack. All of this is enhanced by a beautiful OLED display that provides information on the track currently playing, as well as indications of the FiiO BTR15's operating mode. It's the perfect companion for a smartphone, tablet or computer.
FiiO BTR15: Two ES9219MQ DAC chips and XMOS XU316 USB interface
FiiO has selected two ES9019Q2M DAC chips for their versatility. This DAC is a high-performance 32bit stereo chip with integrated headphone amplification and MQA rendering. Used to their full potential and combined with an XMOS XU316 USB interface, they enable the FiiO BTR15 to support up to 32bit 384kHz PCM, native DSD up to DSD256 and MQA.
FiiO BTR15 picture
Photo of the FiiO BTR15 Bluetooth chip
FiiO BTR15: Bluetooth 5.1 Hi-Res receiver
The BTR15 incorporates a Qualcomm QCC5125 Bluetooth 5.1 receiver chip, offering a reception range of up to 10m and supporting a wide range of codecs: SBC, AAC, aptX, aptX LL, aptX Adaptative, aptX HD and LDAC.
FiiO BTR15: Dual output headphone amplifier
The BTR15's headphone amplifier stage is balanced to preserve a high level of detail and purity in the final sound reproduction. The BTR15 has two headphone outputs: 3.5mm jack and balanced 4.4mm jack. It is capable of delivering up to 340mW of power at 32 ohms on its balanced output, and up to 125mW of power at 32 ohms on its 3.4mm jack output. This means it can power a wide variety of headphones and in-ear monitors on the market.
FiiO BTR15 output power
FiiO BTR15, a connected device
FiiO BTR15: Dedicated application and OLED display
This portable DAC headphone amplifier from FiiO has all the essentials in terms of control: on its side panel, various buttons let you control volume and operating mode. However, if you want more advanced controls, you can use the brand's control application to access settings such as a customizable equalizer.
Product typePortable DAC headphone amplifier
DAC chip2x ES9219MQ
Bliuetooth chipQCC5125
USB interfaceXMOS XU316
InputsUSB-C (charging and DAC)
Bluetooth
Outputs1x 3.5mm jack headphone output
1x 4.4mm jack balanced headphone output
Supported sample ratesPCM 32Bit 384kHz, DSD native up to DSD256 and MQA renderer
Supported Bluetooth codecs SBC, AAC, aptX, aptX LL, aptX Adaptative, aptX HD, LDAC
Bluetooth version5.1
Supported USB protocolUAC 1.0
ScreenOLED
BALANCED OUTPUT MEASUREMENT
Output power2x 340mW at 32Ω
2x 50mW at 300Ω
SNR122dB
THD+N< 0.0008%
Frequency response20Hz-50kHz
UNBALANCED OUTPUT MEASUREMENT
Output power2x 125mW at 32Ω
1x 15mW at 300Ω
Pwer supplyBattery-powered or via USB-C (5V 1A)
Battery550mAh
Battery lifeUp to 8h Bluetooth AAC
Charging time2h
Dimensions32 x 72 x 12.5mm
Weight37.3kg
Package1x FiiO BTR15 portable DAC headphone amplifier
1x USB-C to USB-C cable
1x USB-C to USB-A adapter
1x Transparent plastic carrying case
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9219MQ/Q
Max sampling rate384kHz
Max sampling rateMQA
Max sampling rateDSD256
ClassN/A
2 reviews
Un "compagnon" de balade idéal
Je cherchais un appareil qui améliore, en promenade, la qualité d'écoute de mes téléchargements Qobuz, à partir d'un smartphone, et ce BTR15 remplit sa mission. Exactement le même sentiment joyeux de "musique en liberté" que lors de l'apparition des petits lecteurs MP3. il y a 20 ans, la qualité en plus. J'utilise des écouteurs intra de qualité moyenne (je les casse, je les perds...), moins de 30€, avec des embouts en mousse. Grâce à l'EQ de l'app FIIO, facile à utiliser, mes intras me semblent bien meilleurs. J'écoute surtout du classique. Le BTR15 fait merveille avec la voix humaine. Celle des contre-ténors, en particulier, et ce n'est jamais facile. Aucune fatigue auditive après 3 heures d'utilisation (la batterie : impec) Le prix est très correct. Merci à Audiophonics : service impeccable et, dans d'autres circonstances, des conseils généreux, précis et précieux.
This review has been posted for FIIO BTR15 Balanced Headphone Amplifier Portable DAC ES9219MQ Bluetooth LDAC 32bit 384kHz DSD256 MQA
Floats like a butterfly, stings like a bee!
Fantastic value and power for a tiny headphone amp.
Nice to have both the usual unbalanced 3.5mm and also an even nicer 4,4mm balanced output.
This thing can drive both my kinda hard to drive TruthEars Crinacle One and also my HiFiman Ananda to shaking levels without even breaking a sweat!
Use it as your portable amp for your phone, both by bluetooth with almost flawless LDAC performance or just use the usb dac capabilities to either save battery on your phone by using phone mode or use PC mode to save the DAC batteries, the choice is yours (yes, this also works on a pc, just like a desktop dac!).
I cannot think of any better deal when it comes to an allrounder dac/headphone amp!
This FiiO BTR15 portable DAC headphone amplifier is a small, affordable device, but no less high-performance, since it integrates a number of...
