Headphone Amplifier DAC DSP Equalizer Microphone XMOS 32bit 192kHz DSD128
MiniDSP offers with its IL-DSP a combo that integrates DSP, DAC and headphone amplifier in a compact aluminium housing, allowing use at home or on the move. The DSP offers a flexible 10-band parametric equalizer, ideal for adapting sound reproduction to your listening experience. The IL-DSP also includes a microphone to answer calls received on your smartphone directly.
The IL-DSP's parametric equalizer is easily configured using the software provided by MiniDSP. Fully adjustable filters allow precise adjustment with a boost or cut-off of up to 16dB on each band.
In order to offer excellent audio performance, MiniDSP has chosen to integrate high quality components into the IL-DSP. A USB XMOS XCore200 interface and a 32bit CS43130 conversion and amplification chip provide a signal-to-noise ratio of 120dB and a THD+N of 0.0007% as well as a power of 30mW per channel. High sampling rates are also supported, up to 32bit 192kHz for PCM and up to DSD128.
In use, the IL-DSP is extremely intuitive. Input is made on Micro USB port and output on 3.5mm jack plug. 3 buttons allow you to access all the functions: adjust the volume level, skip to the next or previous track, pause or start playback and finally activate or not the DSP.
Product type | Headphone amplifier, DSP and DAC |
Amplification and conversion chip | Cirrus Logic CS41130 |
USB Interface | XMOS XCore200 asynchronous |
Input | 1x Micro USB |
Output | 1x Jack 3.5mm |
Parametric EQ | 10 band |
Compatibility | Windows Mac OSX Linux Android (OTG) |
Integrated microphone | |
Frequency response | 20Hz - 20kHz +/-0.05dB 20Hz - 96kHz @ 192k |
SNR | 120dB (32Ω, 1kHz, A-Weighted, digital in 0dB) |
Power | 2x 30W (32Ω, 1kHz, digital in 0dB) |
THD+N | 0.0007% (32Ω, 1kHz, 30mW + 30mW, mid gain) |
Supported headphone impedance | 16 - 600Ω |
Supported sampling rates | PCM up to 32bit 192kHz DSD up to DSD128 (DSP not in use in DSD mode) |
Housing material | Aluminium |
Dimensions | 53 x 17 x 9mm |
Weight | 14.5g |
Color | Silver |
Package | 1x MiniDSP IL-DSP 1x USB-C to Micro USB cable 15cm 1x USB-C to Micro USB cable 70cm 1x USB-A to Micro USB cable 15cm |
