No featrued products
An evolution of the famous Dawn Pro, the Moondrop Dawn Pro 2 balanced portable DAC headphone amplifier benefits from numerous improvements. In particular, it features two new CS32198 DAC chips and a HiFi USB interface that supports high-definition sampling rates up to PCM 32Bit 384kHz and DSD256. It also offers HiFi performance with a dynamic range of 132dB and THD of only 0.0001% for a pure listening experience. Another new feature is the ability to adjust the sound using a second-generation interactive online DSP, while keeping the same structure with two independent crystal oscillators and three independent LDO power supplies. Output is easily achieved via a 3.5mm jack or balanced 4.4mm jack with power up to 4Vrms/124mW under16 Ohms.
The architecture of the Moondrop Dawn 2 is similar to that of its predecessor, with two clocks and three independent LDO power supplies, but with a few new components such as a Moondrop UA01 HiFi USB interface and two Cirrus Logic CS43198 DAC/AMP chips. The result is low distortion, superior quality sound with lower power consumption.
Moondrop has incorporated a 100-step, nearly lossless volume control into its Dawn Pro 2 that is completely separate from the source's volume control in order to minimize signal compression when adjusting the volume.
Capable of outputting up to 4Vrms/124mW under a 16-ohm load, the Dawn Pro 2 focuses not only on power but also on timbre for expressive sound reproduction and the ability to drive many headphones and IEMs available on the market.
In terms of performance, the Dawn Pro 2 boasts an SNR and dynamic range of 132dB, as well as a THD+N of just 0.0001% for natural sound and faithful reproduction without background noise.
Dawn Pro 2 users can adjust the equalization of the sound through the new Moondrop app. Numerous settings are available, such as filter type, frequency cutoff, gain, and Q factor. In addition, users can share and download settings from other users and access a library of presets for certain IEMs/headphones. If you don't want to use a phone to make these adjustments, you can also use the “Moondrop Sound-Tuning Tool” web interface, which is even more complete.
Please note that this feature is only available on Android. However, settings made via Android will remain stored in the Dawn Pro 2 for use with a phone running the iOS operating system.
| Specifications | |
| Product type | Portable DAC / Headphone amplifier |
| DAC/AMP chip | 2x CS43198 |
| Input | USB-C |
| Outputs | 1x Single-ended 3.5mm jack headphone output 1x Balanced 4.4mm jack headphone output |
| Supported sample rates | PCM up to 32bit 384kHz DSD up to DSD256 |
| Dynamic range | 132dB @ 1kHz (A-WT) |
| THD+N | 0.00014% @ 1kHz |
| Output power | 2x 124mW @ 16 ohm |
| Output amplitude | 4Vrms@0dBFS |
| General | |
| Dimensions | 11.4 x 42.5 x 23.2mm |
| Package | 1x Moondrop Dawn Pro 2 1x USB-C cable 1x USB-C to USB-A adapter |
| Input | USB |
| Output | Jack 3.5mm |
| Output | Jack 4.4mm |
| DAC / ADC Chip | CS43198 |
| Max sampling rate | 384kHz |
| Max sampling rate | DSD256 |
| Color | Silver |
| Class | N/A |
| Networking | No |
| Remote Control | No |
