E1DA 9039S USB DAC Headphone Amplifier
The E1DA 9039S is a balanced USB DAC / headphone combo combining high sound performance and ultra-compact design, a direct descendant of the 9038S Gen 3. It is based on the latest ESS ES9039Q2M chip, providing high-resolution decoding up to PCM 32bit 384kHz and DSD256, for extremely fine and precise sound reproduction.
4.5 / 5
Reference : 20971
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 17-11-2026.
E1DA 9039S USB DAC Balanced Headphone Amplifier ES9039Q2M 32bit 384kHz DSD256
E1DA 9039S : Front view
Its analogue section is based on a duo of OPA1612 and AD8397, offering impressive output power of up to 2x710mW at 12 Ohm, providing enough power for the majority of headphones and earphones on the market.
Compact and with no internal battery, the 9039S draws its power directly from the device it is connected to (smartphone, tablet, computer), guaranteeing ease of use without compromising performance. Input is via a USB-C connector, while output is via a balanced 2.5 mm jack plug.
The result of rigorous component selection, extensive testing and 100% proprietary code, this DAC boasts reference measurements with a harmonic distortion rate of -125dB, a dynamic range of 130dB and crosstalk of less than -150dB, for pure, detailed sound reproduction free from distortion
We strongly advise against using a balanced to single-ended adapter with the 9039S. This could cause irreparable damage.
E1DA 9039S test by Audio Science Review
"This is more than excellent ! This is better than good - it's world class for such a tiny devices.
And even if a random sample gets 1dB lesser figures, it still measures way better than anything on the market in that category to date."
Product typePortable DAC
Headphone amplifier
Input1x USB-C
Output1x Jack 2.5mm symétrique (pinout Astell & Kern)
DAC chipES9039Q2M
Amplification chip1x OPA1612
1x AD8397
Supported sampling ratesPCM up to 32 bit 384kHz
DSD up to DSD256
Output impedance1Ω @ 1kHz
Output power> 380mW @ 32ohm 1kHz THD+N -124db
> 680mW @ 16ohm 1kHz THD+N -123db
> 710mW @ 12ohm 1kHz THD+N -121db
Dynamic range130dB A-weighted
THD+N-125.66dB on average for 10 samples 32b/96kHz @ 10k 49MHz
-124.77dB on average for 10 samples 32b/96kHz @ 32ohm 49MHz
THD-140dB 32b/96kHz @ 10k 49MHz
-145dB 32b/96kHz @ 10k 24MHz
Crosstalk-150dB @ 1kHz 10k
-143dB @ 32ohm
Load capacitance< 6800pF
Power supply5V via USB
Housing materialAnodized Aluminium
Dimensions48 x 22 x 9mm
Poids12g
Package1x E1DA 9039S
OutputJack 2.5mm
DAC / ADC ChipES9039Q2M
Max sampling rateDSD256
Max sampling rate384kHz
ClassN/A
2 reviews
E1DA 9039 is a great USB DAC for listening music on the go
This USB DAC has great sound, sandblasted, anodized aluminum chassis looks great and is not conspicous, in hands it feels fine. has high resolution, up to 32-bit/384kHz and native DSD256 decoding. It is powerful, rock fans will love it.
Delivery and after-sale service is spot-on. Technical support is fast.
This review has been posted for E1DA 9039S USB DAC Balanced Headphone Amplifier ES9039Q2M 32bit 384kHz DSD256
Connecteur USB-C femelle non conforme
Le connecteur USB-C femelle ne permet pas de connecter le câble USB-C mâle-mâle livré (ni les autres) de manière correcte. Risque de déconnexion intempestive.
Il manque 2-3 mm en profondeur.
Attention de ne pas forcer, sous peine de détruire le dongle.
Dommage, c'est le meilleur DAC / ampli casque de cette catégorie. De très loin !
The E1DA 9039S is a balanced USB DAC / headphone combo combining high sound performance and ultra-compact design, a direct descendant of the 9038S...
