MOONDROP DAWN PRO 2 Portable Balanced DAC Headphone Amplifier
An evolution of the famous Dawn Pro, the Moondrop Dawn Pro 2 balanced portable DAC headphone amplifier benefits from numerous improvements. In particular, it features two new CS32198 DAC chips and a HiFi USB interface that supports high-definition sampling rates up to PCM 32Bit 384kHz and DSD256.
Reference : 21086
59,00 €tax incl.
49,17 € tax excl.
Shipping date: 24-11-2026.
Moondrop Dawn Pro 2 Portable Balanced DAC Headphone Amplifier 2xCS43198 32-bit 384kHz DSD256
MOONDROP DAWN PRO 2 picture
An evolution of the famous Dawn Pro, the Moondrop Dawn Pro 2 balanced portable DAC headphone amplifier benefits from numerous improvements. In particular, it features two new CS32198 DAC chips and a HiFi USB interface that supports high-definition sampling rates up to PCM 32Bit 384kHz and DSD256. It also offers HiFi performance with a dynamic range of 132dB and THD of only 0.0001% for a pure listening experience. Another new feature is the ability to adjust the sound using a second-generation interactive online DSP, while keeping the same structure with two independent crystal oscillators and three independent LDO power supplies. Output is easily achieved via a 3.5mm jack or balanced 4.4mm jack with power up to 4Vrms/124mW under16 Ohms.
The highlights of the Moondrop Dawn 2
Moondrop Dawn Pro 2: HiFi architecture
The architecture of the Moondrop Dawn 2 is similar to that of its predecessor, with two clocks and three independent LDO power supplies, but with a few new components such as a Moondrop UA01 HiFi USB interface and two Cirrus Logic CS43198 DAC/AMP chips. The result is low distortion, superior quality sound with lower power consumption.
The HiFi architecture of the Moondrop Dawn 2
Moondrop Dawn Pro 2: Lossless volume control
Moondrop has incorporated a 100-step, nearly lossless volume control into its Dawn Pro 2 that is completely separate from the source's volume control in order to minimize signal compression when adjusting the volume.
Moondrop Dawn Pro 2: substantial output power
Capable of outputting up to 4Vrms/124mW under a 16-ohm load, the Dawn Pro 2 focuses not only on power but also on timbre for expressive sound reproduction and the ability to drive many headphones and IEMs available on the market.
The output power of the Moondrop Dawn 2
Moondrop Dawn Pro 2: Audiophile performance
In terms of performance, the Dawn Pro 2 boasts an SNR and dynamic range of 132dB, as well as a THD+N of just 0.0001% for natural sound and faithful reproduction without background noise.
The performance of the Moondrop Dawn Pro 2
Moondrop Dawn Pro 2: An app with interactive DSP
Dawn Pro 2 users can adjust the equalization of the sound through the new Moondrop app. Numerous settings are available, such as filter type, frequency cutoff, gain, and Q factor. In addition, users can share and download settings from other users and access a library of presets for certain IEMs/headphones. If you don't want to use a phone to make these adjustments, you can also use the “Moondrop Sound-Tuning Tool” web interface, which is even more complete.
Please note that this feature is only available on Android. However, settings made via Android will remain stored in the Dawn Pro 2 for use with a phone running the iOS operating system.
The Moondrop Dawn 2 app
Product typePortable DAC / Headphone amplifier
DAC/AMP chip2x CS43198
InputUSB-C
Outputs1x Single-ended 3.5mm jack headphone output
1x Balanced 4.4mm jack headphone output
Supported sample ratesPCM up to 32bit 384kHz
DSD up to DSD256
Dynamic range132dB @ 1kHz (A-WT)
THD+N0.00014% @ 1kHz
Output power2x 124mW @ 16 ohm
Output amplitude4Vrms@0dBFS
Dimensions11.4 x 42.5 x 23.2mm
Package1x Moondrop Dawn Pro 2
1x USB-C cable
1x USB-C to USB-A adapter
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43198
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
ClassN/A
MOONDROP DAWN PRO 2 Portable Balanced DAC Headphone Amplifier 2xCS43198 32-bit 384kHz DSD256
An evolution of the famous Dawn Pro, the Moondrop Dawn Pro 2 balanced portable DAC headphone amplifier benefits from numerous improvements. In...
