SHANLING UP5 Portable DAC Headphone Amplifier 2x ES9219C XMOS Balanced Bluetooth 5.0 MQA 32bit 384kHz DSD256
Shanling offers with its UP5 a compact and extremely powerful DAC and portable headphone amplifier combo. The UP5 is based on the UP4, but with many improvements. The UP5 features two ESS ES9219C DAC and amplifier chips, optimized to provide excellent sound quality while taking advantage of reduced power consumption.
2.0 / 5
Reference : 15450
169,00 €tax incl.
140,83 € tax excl.
Shanling UP5
Shanling UP5 DAC Amplificateur Casque Portable 2x ES9219C XMOS Symétrique Bluetooth 5.0 MQA 32bit 384kHz DSD256
Shanling offers with its UP5 a compact and extremely powerful DAC and portable headphone amplifier combo. The UP5 is based on the UP4, but with many improvements. The UP5 features two ESS ES9219C DAC and amplifier chips, optimized to provide excellent sound quality while taking advantage of reduced power consumption. These chips are combined with an XMOS XU208 USB interface for fast and stable signal transmission.
The clock is managed by a 3rd generation custom FPGA, combined with two KDS femtosecond oscillators (45.1584MHz and 49.152MHz) with low phase noise. This design allows a significant reduction of jitter for a precise and transparent playback. The UP5 has both a 3.5mm unbalanced output and two balanced outputs in 2.5mm and 4.4mm jack formats, to suit all uses and all headphones and earphones.
The UP5 can also be controlled remotely via the Shanling Broadcast Control APP. This application provides access to a number of options such as EQ, volume, DAC usage mode and OTA updates.
Shanling also includes a SiSonic microphone with cVc 8.0 noise cancellation technology and DSP in the UP5. This means that you can make calls directly with complete peace of mind.
Finally, the UP5 supports the decoding and playback of MQA (Master Quality Authenticated) files for a listening experience as close as possible to the studio recording. It also supports, via its USB input, PCM streams up to 32bit 384kHz and DSD up to DSD256.
Product typePortable DAC and headphone amplifier
Inputs1x USB-C
Bluetooth 5.0
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
1x Balanced Jack 2.5mm
DAC Chips2x ESS ES9219C
USB interfaceXMOS XU208
Bluetooth chipQCC5120
Output power90mW @ 32Ω, single-ended, single DAC mode
112mW @ 32Ω, single-ended, dual DAC mode
240mW @ 32Ω, balanced
SNR120dB
Channel separationSingle-ended: 70dB @ 32Ω
Balanced: 108dB @ 32Ω
THD+N0.0035% @ A-Weighted, 0.5V, 32Ω
Battery680mAh
Operating lifeSingle-ended : 15h
Balanced: 11h
Charging time2h
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LHDC, LDAC
Supply voltage5VDC 1A
Dimensions68 x 39 x 14.5mm
Weight50g
Package1x Shanling UP5
1x USB-C cable
1x Rear clip
OutputJack 2.5mm
OutputJack 3.5mm
OutputJack 4.4mm
Produit non fini : trop capricieux en attendant une mise à jour du firmware
J'ai le Shanling UP5 depuis quelques semaines avec a priori le dernier firmware dessus (V1.6.0).
La bête est capricieuse sur la gestion du volume et du gain, le switch entre Bluetooth et DAC USB.
Typiquement il doit switcher automatiquement en mode USB dès lors qu'il est connecté à un PC par exemple. Il est bien reconnu par mon PC, mais il faut que je m'y reprenne à plusieurs reprises (ON/OFF, débrancher/rebrancher) afin qu'il soit enfin opérationnel en mode DAC USB. Windows 10 n'aide peut-être pas.
Après le volume. Je trouvais que ça en manquait un peu (bien qu'à 40-45), du coup je switche en high-gain, arrachage de tympans, je remets en low-gain, ben ça change rien, comme si j'étais resté en high-gain, j'ai pourtant bien "Gain = L" affiché.
La portée Bluetooth est minimaliste, ça grésille vite si je m'éloigne de la source à plus de 5m, et encore.
Pas si flagship en l'état. A voir si les prochains firmwares amélioreront l'expérience.
This review has been posted for SHANLING UP5 Portable DAC Headphone Amplifier 2x ES9219C XMOS Balanced Bluetooth 5.0 MQA 32bit 384kHz DSD256
Shanling offers with its UP5 a compact and extremely powerful DAC and portable headphone amplifier combo. The UP5 is based on the UP4, but with...
