Benoit d.
Robert C.
It is difficult to...
Robert C.
Good quality product
This is for DIYers since soldering is mandatory!
If you have basic soldering skills and tools then it is easy and recommended.
Customers reviews - There are 19628 reviews.
gwen G.
DYNAVOX RCA Stereo Cable OFC Copper Gold Plated Connectors 1.5m This Dynavox RCA cable incorporates a 99.99% purity OFC copper conductor to ensure excellent audio signal conductivity and ensure that your system is soundproof.
attention, cable non blindé!!!!
en effet, non blindé, à ne surtout pas installer entre une platine vinyles et une entrée phono.....!!!
gros buzz avec ce cable, disparu avec "vrai" cable blindé......!
ALEXANDROS M.
SMSL SH-8S Headphone Amplifier Balanced OPA564 2x6W 16Ω SMSL offers with its SMSL SH-8s an affordable and efficient headphone amplifier. It uses OPA564 AOPs to deliver, with great precision, a power of 2x6W under 16Ω. It will...
SMSL SH-8S
Excellent for the money,good quility, very-very precise , beautiful airy treble, lacks a bit in bass, mids are a tone up, but with all amps you can fix with eq.
Most important that can listen to hours without fatigue
Flora B.
ASTELL&KERN A&NORMA SR25 Digital Audio Player DAP HiFi 2x CS43198 Bluetooth WiFi 32bit 384kHz DSD256 MQA The SR25 is the second model in Astell&Kern's A&norma range, a high-end DAP that fully embraces the brand's philosophy and technology, now available to the general public. The...
Cher et prise en charge carte sd pas au niveau
Sans doute très bon niveau au son - je n’ai pas eu loisir d’en profiter tant la prise en charge de carte sd et des métadonnees est laborieuse.
Je suis retourné sur un ancien baladeur iBasso certes moins « hype » et plus rustique mais qui, lui au moins, sait lire ce qu’on lui donne !
Sans doute est-ce l’OS qui est mauvais mais à ce prix là c’est le genre de détail qui est peu acceptable !
Kévin R.
TI LME49720NA/NOPB Operational Amplifier OPA Class AB 2 Channel DIP8 (Unit) The Texas Instruments LME49720NA/NOPB is a high performance 2-channel Class AB, high performance operational amplifier (OPA) integrated in a DIP8 package. This ultra low...
Volée de bois vert
Pas d'avis sur cet AOP ?
/ ! Si vous recherchez des basses lourdes et très profondes, passez clairement votre chemin.
La dimension, la fidélité et la justesse sonore qu'offre cet AOP est vraiment incroyable !
Vincent B.
Un super ampli
Ampli extra, conception de qualité, ampli puissant et qui drive tout parfaitement et clairement.
Une fois qu'on installe cette bête, il ne reste plus qu'a améliorer le reste de la chaine lol (la source, le préamp, les enceintes, etc) pour pouvoir bénéficier de toute son ampleur et de toute sa qualité.
Ma seule critique est ailleurs que dans le produit : le carton de suremballage était litérallement foireux et mal scotché (1 pauvre bande de scotch qui laissait le carton entreouvert...). j'ai eu une petite frayeur que les cables en vrac dans le carton ne manquent à l'appel. Le service colissimo ne semble pas au top au vu des coups pris aussi sur les coins du carton de suremballage. Quand on a 1000 euros de commande dans un tel carton on s'attend à ce que de plus amples précautions soient prises (par l''expéditeur, par le livreur).
Sinon je le répète : le produit est fantastique et de très bonne facture par audiophonices ! vous pouvez foncer !
Théodore E.
Hautement recommandé!
Utilisé pour alimenter un ampli AIYIMA A07, cet adaptateur délivre sur tous les aspects. Un chassis tout métal, très solide, d'une finition de très haute qualité -- les photos du site ne lui font pas justice. Il fournit toute la puissance nécessaire sans chauffer. Son poids non négligeable fait qu'il reste solidement en place, ce qui n'est pas le cas des transformateurs avec chassis en plastique qui sont menés par le fil d'alimentation. A ce prix, ce produit mérite une note de 20/20.
Christopher R.
Furutech dps 4.1
J'ai en ma possession le câble Furutech dps 4.1 depuis maintenant 4 mois. Ce que je peux vous dire dessus c'est que c'est un câble secteur de folie. Le mien est couplé aux connecteurs Furutech fi 50/fi e50 r NCF. Le son est d'une pureté sans équivalent. Tout est très équilibré, l'image sonore est très ouverte sans être envahissante. La transparence frôle la perfection, tous les micro détails passent et engendrent un son que vous ne retrouverez pas même avec l'excellent Furutech fps 55n. J'ai conscience que le tarif au mètre peut être un frein financier et/ou psychologique mais l'écart de tarif est proportionnel à l'écart d'écoute qu'il y a entre ce câble et le fps 55n, croyez moi !!!
Je l'utilise sur un dac Atoll dac 300 mais je l'ai également testé sur mon ampli Octave v80se. Les 2 électroniques font vraiment un grand pas en avant avec l'apport de ce câble. Il se passe plus de chose en le branchant sur la source que l'amplification, en tout cas me concernant.
Je l'ai également testé sur les électroniques Accuphase e800, Audio analogue, Cambridge audio cxn v2, Atoll ph100 et à chaque fois c'était une évolution considérable. Pour conclure j'ai possédé des câbles haut de gamme chez Audioquest (hp William Tell, secteur Tornado) ils ont tous été remplacés par des câbles Furutech et clairement sans regret.
Musicalement.
henri g.
pas toute la meme couleur 1 sachet 9 VIS dorees 1vis a tete ronde et 1 sachet 10 VIS cuivrees
henri g.
pas toute la meme couleur 9 DOREES
RENE R.
THE MAJESTIC
APRES PLUS D'UN MOIS D'ECOUTE LE CABLE S'EST OUVERT LE MEDIUM EST PLUS PRESENT ET LE SON EST ENCORE PLUS COHERENT. IL S'AGIT VRAIMENT D'UN TRES BON PRODUIT, SUR MA LINN IL REMPLACE UN CABLE VAN DEN HULL QUE JE TROUVAIS AGRESSIF ET SANS NUANCE. DE PLUS J'AVAIS POSSEDE AUPARAVANT LE MODELE HIGHLANDS DU MEME FABRICANT MAIS JE PREFERE CELUI-CI PLUS COHERENT ME SEMBLE T-IL. DONC UN TRES BON CABLE AU TRES BON RAPPORT QUALITE PRIX ET QUI CONSTITUE UNE TRES BONNE AFFAIRE.
Nicolas Q.
TOPPING BC3 audio reveicer Bluetooth 5.0 aptX HD LDAC DAC ES9018Q2C 24Bit/96kHz Black Battery-powered Bluetooth 5.0 Wireless High-Res receiver with integrated ES9018Q2C DAC. Offers line out, headphone out and even mini-toslink optical out. Compatible with...
Questionning manufacturing quality
I had to return my BC3 after 5 months of operation as it suddently stopped functionning. Audiophonics provided me with a new product (thanks for a good ASS process) but one can wander if the manufacturing quality is at rigth level.
Sebastien C.
Esthétique mais défaillant
Câble très esthétique, mais ce n'est malheureusement pas le premier critère à prendre en compte. Les connectiques sont mal calibrées, les contacts ne font pas correctement, ce qui rend totalement inutile le plaquage Or, et le câble en lui même. Le prix est donc très surestimé pour un câble "Made in china" fonctionnant plus mal qu'un câble RCA acheté chez Carrefour en 1998. Concrètement, la connexion de la voie gauche ne ce fait pas avec ce câble, mais fonctionne avec mon vieux RCA de grande surface. Je suis d’ailleurs intéressé pour connaitre votre politique de retour sur ce type de matériel.
C'est anomal, nous n'avons pas de problème avec la marque.
Votre câble est de toute évidence défectueux.
Contactez mes collaborateurs du SAV qui feront le nécessaire.
Alain L.
une perle rare , un RQP HORS NORMES.
J'ai osé placer ce préampli au coeur d'un système dont les éléments valent trois fois son prix. Et bien quelle surprise de l'écouter chanter au même niveau. De par sa transparence , sa neutralité et son silence de fonctionnement, ce préampli fait curieusement penser à un modèle passif.
l'image est large, il y a de l'air entre les pupitres. Il faut cependant bien lui laisser une période de "réveil" ou rôdage comme vous l'entendez. Il chauffe beaucoup pour un préampli, bien le laisser aéré est quasi indispensable. lui laisser le temps d'arriver à pleine temporisation sera également un plus musical. En conclusion : une petite merveille INCONTOURNABLE pour son prix.
Toute la différence avec un découpage basique
Cela fonctionne parfaitement bien; On a de la finesse en plus vu le recul phénoménal du bruit ! Bien supérieure à une alimentation à découpage à résonance qui sont très puissantes mais n'atteignent pas la finesse réalisée par la marque Ifi sur ses Power alimentions audio.
Excellent distributeur en Aluminium
J'en avais déjà un avec moins de prises. C'est le même en plus grand, avec les mêmes qualités. Je recommande.
Un raccord jack qui reste plaqué au piano qu'il relie au pédalier. On supprime le risque de l'accrocher en se déplaçant et de forcer les contacts dans l'embase qui l'accueil. Super !
Excellente fiche secteur
Produit excellent s'adapte à différentes inclinaisons surtout lorsque le câble est gros et ne se courbe pas trop facilement: il est bien rangé ainsi grâce à cette disposition. Juste trouvé la vis manquante qui retient la liaison terre schuko. Ne m'en suis pas aperçu tout de suite, mais un jour d'orage violent, en débranchant mes équipements, les broches de terre sont restées dans la prise. J'avais heureusement de la visserie compatible et j'ai pallié le défaut sans avertir le SAV. Il y avait trop de d'écart entre ma commande et le jour où je m'en suis rendu compte. Donc excellent produit, mais lorsque vous le recevrez vérifiez bien que la petite vis est présente pour le signaler dès réception à Audiophonics. Je donne 5 étoiles au produit, sachant que dans les cartons de production et d'emballage ce type de vis peut facilement s'égarer si elle n'a pas été suffisamment serrée par le fabricant.
Christian N.
Excellent petit DAC. Donne sa pleine mesure sur le HiRes et en particulier en DSD sur l'entrée USB avec Foobar (ne pas oublier de télécharger le pilote ASIO chez SMSL), son très équilibré, détaillé et neutre. Les filtres ne me paressent pas franchement nécessaires, peut-être sont-ils utiles sur un système plus ambitieux que le mien, j'utilise principalement ce DAC en sortie casque avec un HD600. La télécommande est un peu capricieuse et l'utilisation pas franchement intuitive, J'aurais apprécié quelques commandes en face avant pour éviter l'arborescence des menus par franchement intuitive pour un usage famillial. Je recommande vraiment ce produit.
Luis V.
Great Versatility
I bought 2 modules of these amplifiers to be able to power a dual 4 Ohm coil 1000 Watts Subwoofer, the results are surprisingly good, the combined amplifiers work perfect and at warm temperatures even in heavy loads.
I am amazed, by the incredibly reduced size, of the power and sound quality this units can provide.
Luis V.
Screw-in Rubber Foot 38x20mm (Unit) This rubber foot will allow you to guarantee your HiFi equipment a great stability. They also allow you to dampen the vibrations of your system.
Great Product
Awesome product to elevate and isolate subwoofers from the floor, the rubber is very soft and very well finished.
Bruno l.
Extraordinaire !
En décembre 2019 j’ai acheté un ifi Audio AC iPurifier.
Comme je l’ai écrit à l’époque, j’ai pris une claque monstrueuse ! Cet appareil fait un boulot extraordinaire. Comme tous les appareils de la marque IFI, il a transformé ma chaîne hifi comme jamais pour un prix ridicule par rapport aux éléments HIFI traditionnels.
Depuis j’en ai acheté un deuxième, La position de l’appareil sur les nourrisses peut donner des résultats légèrement différents, il faut trouver l’optimum, mais c’est grandiose !
De mon expérience, il en faut un plus près de la source et un au niveau de la prise murale. Les amplis doivent être en tête de nourrisse.
Je m’amuse très souvent à prêter à des amateurs de HIFI mes filtres secteurs actifs. Des personnes qui pensaient avoir optimisé parfaitement leurs installations à plusieurs milliers d’Euros,
A chaque fois c’est le même scénario ! Tout est mieux ! Les aigus sont plus propres, la position des interprètes devient évidente, le suivi rythmique est bien meilleur, on a l’impression d’avoir plus de grave, plus de medium, plus d’aigu, bref plus de musique,
Pour vous donner une idée, les deux dernières chaînes utilisées étaient composées de :
Chaîne Linn complète ampli + prérempli + lecteur CD avec une alimentation Linn séparée pour chaque élément et des enceintes PMC
L’autre encore plus haut de gamme, lecteur Wadia, convertisseur dCS, amplis Cello et enceintes Martin Login.
A acheter de toute urgence, même 10 fois plus cher ce serait encore une affaire par rapport à ce que cela apporte. Merci à Audiophonics de proposer tous ces produits abordables et réellement efficaces .
Jean-François T.
J'ai commandé ce kit en Novembre 2020 pour remuer les vieilles JBL L36 qui me servent à la restitution sonore de la TV, via une FreeBox Mini 4K et sa sortie TOSLink. Ces excellentes enceintes se caractérisent par un faible rendement et nécessitent de ce fait un ampli puissant. Les recommandations de JBL allaient en gros de 50W à 125W. Le précédent ampli (un Sure basé sur le TAS5630) avait cramé au bout de 3 ans environ...
Parmi les modules proposés par Audiophonics, rares sont ceux accompagnés d'une documentation aussi détaillée (un peu trop verbeuse d'ailleurs). Ce kit est de plus un des rares ne mettant pas en avant des performances "impressionnantes" sur charge de 2 ohms. Non, il est ici question de 8 ohms, et la doc précise son domaine d'utilisation : la vraie audio, pas la pleine puissance RMS avec un facteur de marche de 100% qui n'est utile que pour piloter un moteur par exemple ! Peu d'informations sur le web, mais tout de même un test avec des équipements de labo bien plus évolués que les miens ; conclusions élogieuses.
Moins cher qu'un T-Amp, très proche sur le papier, pas d’esbroufe dans la datasheet, kit complet ampli + alim, entrées différentielles permettant un câblage anti-pompage sans ajout d'un AOP inverseur = décision d'achat.
Premier test sur banc, avec charges résistives réglées sur 8 ohms. Sinus 1 KHz en sortie de géné BF, et recherche de la puissance maxi. Résultat absolument conforme : ça coupe à 35V RMS en sortie, soit 153W et un gain d'environ 55 (mesuré un peu à la louche, trop pressé pour affiner !). Le radiateur est alors brûlant ! (ces conditions sont totalement irréalistes, très éloignées d'une utilisation réelle)
Ensuite conditions réelles cette fois : un block buster, à très haut volume sonore. Aucun souci. Aucune fatigue auditive. Scène sonore précise et détaillée. Je veux dire par là absence de saturation, de compression, pas de variation gauche droite selon le volume, les chuchotements des acteurs restent parfaitement intelligibles au milieu d'explosions, et grande dynamique. Cette fois très peu d'échauffement, ce qui est logique (je n'ai pas mesuré la puissance RMS lors de ce test).
J'avais quelques doutes à propos de la dissipation de chaleur, et de l'extrême miniaturisation. Et bien ça marche parfaitement. Les radiateurs de l'alim et de l'ampli sont vissés au capot en alu du boitier Galaxy Slimline 1U, conformément aux recommandations. C'est à peine un peu tiède.
Une critique cependant : l'épaisseur du PCB : 1.6mm ; 2mm auraient étés préférables pour deux raisons. Un PCB de 2mm aurait donné une hauteur totale de 39.90mm au lieu de 39.50 mm après montage sur colonnettes de 10mm (mesure faite sur marbre avec une colonne de mesure). Avec 39.5mm, soit on ajoute des rondelles de 0.5mm sous les colonnettes puis de la pâte thermique, soit on place un conducteur thermique silicone de 0.5mm entre dessus des radias et dessous de la face supérieure du coffret 1U, ou alors on accepte de surcontraindre le montage ce qui n'est pas vraiment top pour les PCB... Je n'ai rien lu à ce sujet dans les docs, les modules ne sont pas livrés avec un conducteur thermique adapté, et Audiophonics n'en propose pas à son catalogue. J'ai été obligé d'en commander sur Ali...
Très satisfait donc.
Qualités sonores exceptionnelles.
Ce circuit SPARKOS Pro est encore très supérieur musicalement à la version de base pourtant déjà remarquable.
Il transfigurera n'importe quel montage utilisant un AOP.
Bien alimenté on peut comparer sa qualité audio à celle des circuits discrets des préamplificateurs audiophiles les plus haut de gamme.
Un réglage d'offset de sa sortie ajoute encore à son universalité d'emploi.
Excellente alimentation
Cette alimentation à prix très modéré est excellente!
Elle est à la fois silencieuse et très stable sur les tensions CC choisies en sortie.
( transfo Rcore 2 X15V ou 2x 20 selon le besoin).
Elle peut sans crainte être utilisée pour tout circuit classique et même audiophile même de très haut niveau.
Vincent b.
bon découlpeur
sous un dac R2R, le meilleur découplage que j'ai pu obtenir,
tout est plus net
Vincent b.
excellent cable : RQP imbattable
comparé à des câbles plus cher, celui ci s'est avéré très homogène, équilibré et détaillé... donc , d’emblée un bon choix
Honnête DAC
Pour un tarif inférieur à 100 euros,appareil très complet en possibilité de connection:utilisé en coaxial sur platine ,en usb pour écouter de la musique en streaming:son agréable, belle image stéréo
Essaye en Bluetooth : forcément c'est très moyen,pour ma part sans interet
Gros point negatif:le bloc d'alimentation 12 volts de qualité très médiocre,avec en plus un câble très court
J'ai pour ma part récupére une alimentation avec un transfo classique à enroulements:plus de précision et de clarté
ARYLIC S50 PRO Lecteur Réseau Multiroom WiFi Bluetooth Apt-X HD DAC ES9023 ADC AK5720 The S50 Pro from Arylic is a concentrate of functionalities that will allow you to realize a complex audio installation at an affordable price.
Préampli et lecteur réseau intéressant mais perfectible.
Déballage : belle présentation, discret, télécommande même format que alientek d8 auquel il est branché. Petite alimentation. ecran sobre et dimmable.
veille reglable.
on aurait aimé un cable optique ou coaxial.
installation : après allumage il faut se connecter par wifi à l'appareil depuis l'application 4stream, en selectionnant sur le telephone le reseau du s50, bien penser à accorder droits à 4stream pour tout et permettre la connexion même sans acces internet. Si cela bloque, changer de telephone (mon 1er ne me demandait pas assez vite les droits à accorder ou blocage). Ensuite 4 stream vous demandera le mot de passe du routeur ou box wifi pour s'y connecter. Le lecteur reseau me propose de telecharger et d'installer un update, c'est fait en 2 minutes.
essai 1 : le nas, ici c'est juste un disque ssd sur mon routeur netgear, partage smb ou dlna. Parfait, acces sans aucune coupure, tous les fichiers visibles, navigation par dossier. les pochettes sont visibles sur le telephone avec 4stream (qui est connecté au routeur maintenant), sur l'appareil on a le titre et l'artiste, un peu comme l'afficheur d'un lecteur rasptouch. 4stream permet la navigation, le volume, les favoris (12) d'accès rapide.
sortie optique, rca ou coaxiale essayé vers l'alientek. très léger souffle, c'est l'ampli. Je vais l'utiliser en optical out.
treble et bass seulement, pas de balance, lecteur non gapless.
Pas d'accès à grand chose comme parametres, la possibilité de changer de nom multiroom. pas d'egaliseur.
Qualité sonore c'est très bien après quelques morceaux, il faut surtout eviter de toucher de trop aux sources, sinon coupe, pareil pas trop toucher aux menus de 4stream, si on commence à vouloir naviguer sur d'autres sources musicales, celle jouée va se couper. Il y a un léger bip quand on aumente ou baisse le volume par la telecommande, choix discutable non modifiable.
essai 2 clef usb : le site arylic le previent c'est pas le point fort, en effet, s'il va reconnaitre une clef de 256go il n'a scanné que 889 morceaux de la clef, c'est 1000 max. ils sont rangés par navigation de dossier depuis 4 stream, le son depuis la clef est moyen, certains morceaux sont manquants en fonction de leur codec et qqfois cela saute. Pas de pochettes lues par clef. Egalement quand on branche une clef la lecture en cours se coupe.
essai 3 : bluetooth, c'est bluetooth entrant, par exemple pour l'acces du xduoo XIII, touche bluetooth de la telecommande puis appairage classique. nickel, pas de transmission vers un casque du s50+.
il me reste encore à essayer de brancher par exemple un lecteur cd pour voir sur aux in ou optical in.
essai radio : depuis 4stream recherche de france inter dans netradio, on peut lire les rubriques. marche très bien.
essai lecture des fichiers audio presents sur le smarphone par 4stream, pas de souci particulier, on peut lire sans appairer par bluetooth.
essai service en ligne type spotify ou autre, je n'ai pas de services payants cela devrait marcher sans probleme.
Au final lors de ce 1er branchement, plusieurs heures qu'il tourne, sans chauffer, il est agreable, j'aime la telecommande, l'ecran qui diffuse le morceau, le son est très bon. Aucune coupure en wifi depuis le routeur. Apres des tentatives de lecteur rasperry pi avec moode et runeaudio qui ne voyait pas mon dlna , je suis satisfait de cette partie.
j'aurai aimé avoir un selecteur de source defilant avec choix de la source en 2 fois, ici si on branche une clef usb, si on connecte un cable ou si on change sur 4stream de rubrique la lecture en cours se coupe brutalement. On peut alors difficilement le conseiller à des gens trop exigeant, et aussi le manque du gapless. c'est le gros point noir du tableau.
Drole de choix ce port usb pour clef qui n'accepte pas les disques et qui sert à rien au final, sauf a depanner si quelqu'un vient avec quelques fichiers car vaut mieux connecter un telephone par le bt à ce moment là. on aurait preferé une entre asynchrone pour un pc.
il manque cruellement plus de personalisation de l'appareil, ainsi choix du bip telecommande, un acces par navigateur en http (à venir peut etre d'apres le site ? oui car l'appareil a une ip, non fixe pour l'instant mais n'importe quel routeur peut fixer l'ip en fonction de son adresse mac. On a un egaliseur trop pauvre.
on a quand meme la mise en veille reglable, ainsi qu'une fonction reveil pas essayé encore.
pour un bricoleur avec de multiples sources, possedant plusieurs ampli fda ou classe ab analogique, des sources numerisées ou analogiques, c'est quand même un outil perfectible mais intéressant.
Acheté pour essais,convaincu que des câbles hp "pas cher" provenant du monde pro sont au niveau de câble ésotérique vendus à des tarifs exagérés...bref sur mon système très très bien,grave étendu,médium aigu naturel.je les préfère aux canare qui du coup paraissent plus sec avec un grave moins profond
Ce ampli ,plutôt bien fini,ne dispose que d'une seule entrée,s'apparente plus à un ampli de puissance avec un potentiomètre qu'a un intégré.
Peut importe, connecte à un dac le résultat sonore très bon:plutôt neutre, mais pas fatiguant même en montant le volume.
J'ai apprécié le mariage avec des câble hp sommercâble 240 mk2 qui apportent un peut plus de veloutée de chaleur.
Dès que possible,je vais rajouter un vrai preampli séparé, je pense gagner en dynamique et clarté
Préampli et lecteur réseau intéressant perfectible.
veille reglable.
pour un bricoleur de muliples sources, essai, possedant plusieurs ampli fda ou classe ab analogique, des ources numerisées ou analogiques, c'est quand même un outil perfectible mais intéressant.
Iida Y.
Excellent Performance in Small Box
I have purchased HPA-S400ET to compare with Ncore amps(NC400 and NC250MP both dual mono).
This is one of the best power amplifiers.
- Smaller size than HPA-series box
- Easy to change preferable gain
- Easy to change interface OP amps
I have checked with
(a) default ( 20dB Gain and OP amp = LM4562NA)
At first it came to us, it sounded somewhat shiny than NC400.And details was decreasing from Ncore400.
After burn-in several hours, it changed to smoother and little shiny, to better normal hi-end quality.
It may require some burn-in hours for (maybe) large power supply(SMPS1200A400).
(b) OP amp JRC MUSES 8920 and setup gain 25.3dB
After burn-in I have tried to change gain and OP amps.
I was very surprized at upgraded sound when I changed to 25.3dB and MUSES8920.
I strongly recomend to try to change OP amps and change gain to fit to your audio system characteristics.
You will find the best matching combination with gain and OP amps.
With Size , sound characteristics and adjustable functions (gain and OP amps) , I am very satisfied with LPA-S400ET.
Laurent J.
Une belle surprise pour la musique !
Pour info, j'ai utilisé ce MOGAMI 2972, pour fabriquer des straps pour mes enceintes ATC (Triple Bornier). Quelle belle surprise auditive, la musique est vraiment plus nette au point de lever ce voile qui cachait des trésors de détails sur les instruments et les voix. Même la scène sonore est vraiment nette, je m'attendais à une petite amélioration par rapport aux plaques de métal du bornier d'origine...en fait plus je passe mes morceaux que je connais parfaitement, plus je me régale d'une réelle et belle amélioration. Merci encore à Audiophonics de proposer des produits triés pour leurs qualités. Laurent J.
Laurent J.
Très bon rapport Qualité/Prix
avec un peu de recul, je peux donner mon avis sur les câbles de modulation SOMMERCABLE EPILOGUE : utilisés entre mon DAC et mon ampli, ils sont fidèles au messages musicaux, pas colorés, plutôt neutres, RAS, font le job ! Comparés à mon câble TELLURIUM QBLACK (utilisés pour ma platine CD, ils sont excellents) les SOMERCABLE sont inférieurs mais restent bons. Toutefois, les Tellurium sont 4 fois plus chers...donc le SOMMERCABLE reste d'un très bon rapport qualité/prix.
LALU P.
Surprenant !!
Je me décide à changer de configuration et après plus de 15 ans de bons et loyaux services je remplace mon ampli Linn AV5125... choix très difficile de remplacement, il était épaulé par un dac Naim V1, j'ai opté pour un Nad Master m32, mais sans vouloir exploiter la partie amplification car en deça de mes attentes. sur les conseils avisés d'Audiophonics je me suis tourné vers cet ampli, septique, très septique même, mon premier choix s'était orienté vers de l'AudioGD, mais j'ai suivi ce précieux conseil. j'ai demandé à ce que soient installés les AOP sparkos, et que l'ampli soit réglé en config 2... 3 jours après ma commande, la réception ! J'ai lu dans d'autres commentaires que l'emballage était sommaire et je m'attendais donc à recevoir un ampli avec un emballage sommaire il n'en n'a rien été car l'ampli est parfaitement emballé je dirais même doublement emballé est parfaitement protégé j'apprécie toujours les envoie soignés et je ne suis pas déçu... Place à l'installation... et première écoute.... Mon angoisse monte, le son est étouffé, pas de spacialisation...je me dit attendons le rodage sans trop écouter pour ne pas s'habituer à un son de m...après deux jours durant lesquels il a tourné en moyenne 10h, là ce n'est pas une claque mais un hypercut !!! je trouvais mon association Linn/naim excellente et aujourd'hui j'en viens à me dire que j'avais une écoute basique... aujourd'hui tout est défini parfaitement en place, mes enceintes, des Tannoy dc8t, exprimant tout leur potentiel dînas les aigus, les graves sont détaillés, précis non baveux et d'une pureté déconcertante... je suis stupéfait de la qualité d'écoute. mes câbles de liaisons et d'alimentation sont les même qu'avant... Merci Audiophonics pour cette réalisation !!
Alain S.
Exceptionnel
Après avoir longuement fait le tour des produits de ce type sur le marché ...
Le E1DA se est une référence absolue, utilisé avec des intras de qualité il en révèle tout le potentiel en offrant un son avec un punch et une dynamique hors du commun !
A essayer absolument (vous le garderez)
Christian O.
Une boule d'énergie
Après de longues heures d'écoute, je peux dire que ce classe D fait aussi bien, sinon mieux dans les micros informations, que mon Mc Intosh MA 6300 (16 fois plus cher). Le smsl tient d'une main de maitre mes cabasse catalane 500. Je plussoie à ce qui a déjà été dit sur l'avenir de la classe D , dans le domaine de l'amplification. Je recommande cet article.
Denis Gabriel G.
Suite aux conseils d'Audiophonics j'ai acheté cette "toute petite chose" pour redonner vie à un HD 600.
Bien sur il faut rajouter un câble symétrique a 25€ facilement trouvable sur ALI...
Le résultat est excellent. Le casque a retrouvé une seconde jeunesse : plus de précision, plus de dynamique, plus de spatialisation.
Merci encore à Audiophonics pour la qualité de leurs conseils.
Excellent cable
Un câble que chacun devrait essayer. Un peu gros à caser...
N'ajoute rien et n'enlève rien le but d'un bon câble....a prix contenu
Très bon produit. Je n'emploie que ces bananes qui donnent entière satisfaction...
Tres bien
Il faut se battre pour les installer, mais c'est un produit qui termine bien les câbles...
Philippe L.
Excellent rapport Q/P !
Une scène sonore très large, beaucoup de détails et un grave apaisé (mais présent) par rapport à mon câble précédent. Ne pas hésiter à marier avec des bananes de qualité.
jordy v.
Great Product
Like the I2S passthrough. With some soldering, you can add a DC power input.
Bruno M.
Impec
Pas de bouton off mais super produit qui va a l'essentiel!
Jean-François T.
Presque parfait.
Parfaite usinabilité de cet aluminium dont j'ignore la nuance (probablement du 2017 ?). Ne colle pas à la fraise (2 dents pour l'alu !), et pas obligé d'usiner en UGV sous arrosage haute pression... Résultat parfait.
Cependant, pourquoi cette façade n'est elle pas livrée avec 4 vis traitées noir (par exemple phosphatées, c'est pas cher...) ?
Cette façade devrait être proposée directement comme option des boitiers compatibles en lieu et place de celle livrée en standard.
Le distributeur français devrait être en mesure de faire pression sur le fabricant italien.
Un kit RRRrrr (ça va être tout noir) devrait être proposé directement. Façade 10mm noire + dessus alu anodisés noir + visserie noire.
Pas un problème chez moi (énorme stock de visserie), mais probablement pénible pour celui qui a pour seule source le bricomachin du coin lorsqu'il s'aperçoit du problème...
(oui, je sais, je pinaille...)
Jean-François T.
Parfaite usinabilité de cet aluminium dont j'ignore la nuance. Ne colle pas à la fraise (2 dents !), et pas obligé d'usiner en UGV sous arrosage haute pression... Résultat parfait.
Son épaisseur (2.0mm) impose l'utilisation de vis tête fraisée M3 maximum. 2.5 ou 3mm donneraient un peu plus de possibilités.
Jean-François T.
Jolis (même si on ne les verra pas sous un appareil), mais le joint torique qui sert d'antidérapant n'est pas fixé. Prévoir un peu de colle cyanoacrylate. Ou alors se préparer à la chasse, à plat ventre sur la moquette ! (vécu)
Jean-François T.
Très joli boitier, mais...
...pourquoi ne pas le proposer directement avec façade noire et dessus aluminium ??? Probablement pour pousser le client à acheter ces pièces séparément. Pas bien grave, les tarifs étant contenus. Mais ces boitiers pourraient être proposés avec les options afin d'éviter de se retrouver en fin de projet avec des éléments inutiles.
Plus ennuyeux : il y a un vrai problème. L'anodisation et la peinture ne permettent pas un continuité électrique, et donc d'établir une équipotentielle indispensable pour d'évidentes raisons de sécurité des personnes. Un boitier métallique dans lequel se trouve une alimentation secteur DOIT avoir toutes ses parties métalliques exposées équipotentielles et reliées à la terre ! Raison pour laquelle je retire une étoile.
Le workaround n'est pas compliqué. Là où un contact entre deux éléments métalliques est nécessaire, il suffit d'éliminer la peinture ; un peu de décapant peinture appliqué sur le revêtement à l'aide d'un coton-tige, puis rinçage.
Pour les parties anodisées, une goutte de soude caustique appliquée de la même façon, puis rinçage à l'eau. Soude caustique ou déboucheur de canalisations en contenant (c'est en général le cas). Donc une grosse étoile de moins.
Le montage est pénible à cause des écrous placés dans des rainures. Des écrous carrés auraient un peu facilité les choses. Mais bon, avec un peu de patience et d'astuce, on y arrive...
Andreas D.
Pure High Level Sound
I'm running it for a couple of months. It's paired with a Trigon Energy Amp through XLR and the sound is amazing! For me is the sound much more better than from the Lindemann Limetree Network and the Lumin D2. I had both of them! I only use the free version of Volumio, because I'm just streaming from a NAS. Even If you are not familiar with PI or DIY give IT a chance...it's realy easy!!!
jean paul g.
ce que j'espérais
rien à redire sur ce produit qui comble mes attentes , je l'ai branché sur mon DAC magnifique , j'ai mis des protections dans les secondaires du transfo d'alimentation et à l'intérieur de mon boitier j'ai mis deux ventilateurs SILENCIEUX de diamètre 8cm face au radiateurs pour être tranquille , l'écoute sur mes Triangle Antal ....trop bien le prix aussi .
