Multi Strand Wiring Cable 0.75mm² Yellow / Green
Lapp Kabel's cable wire H05V-K consists of a multi-stranded copper conductor with a cross-section of 0.75mm² and a PVC sheath. It ensures very good conductivity for optimal signal transmission.
Product type | Wiring cable |
Conductor material | Copper |
Insulation / Sheath | PVC |
Conductor section | 0.75mm² |
External diameter | Ø2.4mm |
Nominal voltage | 300/500V |
Test voltage | 2000V |
Temperature range | -40°C / +80°C |
Color | Yellow and green |
Quantity | Sold by the meter |
Diameter (mm) | 2.4 |
Length (m) | Sold by length |
Number of conductors | 1 |
Insulation material | PVC |
Shielding | No |
Section (mm²) | 0.75 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Ground / Shielding | No |
