Filtered Power Distributor 8 Sockets Aluminum Silver
The Ludic Heimdall filtered power distributor effectively eliminates any unwanted interference from the power grid or other connected devices. It thus allows your devices to deliver their full potential for high quality listening.
The components of this power distributor are concealed under a solid brushed aluminum frame with a damped subframe to reduce mechanical vibrations. The power strip consists of 8 high-quality Schuko sockets. The input is made on an IEC C14 connector and will allow you to use a high-performance cable instead of the supplied one.
The power distributor also includes surge protection to effectively protect your devices. A vumeter on the front panel indicates the operating status of the power strip and an LED illuminates red, indicating the need to control the grounding. Two pushbuttons allow them to turn on or off the two power supply rails independently.
The vumeter only lights up when the "2" button is pressed and line 2 is powered.
Product type | Filtered power distributor |
Input voltage | 220V AC, 50/60Hz |
Input | 1x IEC C14 |
Outputs | 8x Female Schuko |
Max power | 3000W |
Max load | 15A |
Surge protection |
Housing material | Brusshed aluminum |
Color | Silver |
Dimensions | 31 x 13 x 11cm |
Package | 1x Ludic Heimdall 1x Power cable |
