By buying this product you get 109 loyalty points
With its S15, FiiO unveils a very high-quality audio streamer. In fact, it rivals many high-end streamers for a price that defies all competition. Ultra-complete, this device offers numerous streaming solutions thanks to its Android 12 operating system, while relying on a combo of AK4191EQ + AK4499EX DAC chips for top-level audio performance. It supports sampling rates up to PCM 32bit 768kHz and DSD512. It can also act as a preamplifier on its RCA and XLR line outputs. Thanks to its attractive color touch screen and operating system, it provides access to various streaming services such as Qobuz, Tidal, Amazon Music and Spotify.
It also features Bluetooth 5.1 with a Qualcomm QCC5125 chip and compatibility with DNLA, Airplay and Roon protocols. In terms of connectivity, it's not to be outdone, with a USB-C input, an HDMI input, TOSLINK optical and SPDIF coaxial input/outputs, as well as RCA and XLR line outputs.
This DAC chip combo separates analog and digital signal processing for the most accurate sound reproduction. An XMOS V16AOP controller and timers ensure smooth operation.
This high-performance, low-latency chip offers a high level of compatibility and supports high-resolution streams up to PCM 32bit 768kHz.
This Bluetooth chip enables the S15 to process high-definition codecs such as aptX and LDAC. Moreover, the bi-directional function lets you send a stream to Bluetooth headphones or speakers.
A master chip, it enables the S15 to integrate the Android 12 operating system and ensure fluid navigation on its screen.
The FiiO S15 streamer features an ultra-low-noise 35W linear power supply to power all its audiophile components. This power supply is furthermore coupled with four Elna 4700µF capacitors to ensure high current capacity. It's also worth noting that each stage of the network player is isolated for protection against interference and improved dynamics for clear, pure sound reproduction.
The analog circuitry of the FiiO S15 benefits from a fully balanced architecture from the DAC to the preamplifier stage. This considerably reduces noise and delivers a pure signal to the streamer's outputs. The outputs also feature both fixed and variable levels, allowing the S15 to be used as a preamplifier. In fact, the analog output stage is based on OPA1612, ensuring high voltage levels and good dynamics.
The FiiO S15 features a large color touchscreen on its front panel. The Android 12 interface can be accessed via this for easy access to the various services. In addition, numerous interfaces are available, such as a vumeter, and the home screen is customizable.
An app lets you control the S15 remotely via your phone for the ultimate user experience.
A proprietary algorithm and interface provide the FiiO S15 with 10-band equalization, including gain, frequency, bandwidth and more. This function is available for all S15 operating modes, and can even simulate a specific frequency response.
The FiiO S15 supports HDMI 2.0 as input and is capable of outputting it as HDMI ARC or HDMI I2S via the two dedicated ports. This feature is very practical for anyone wishing to enjoy an immersive TV setup. The HDMI interface supports up to 24bit 192kHz and CD quality on the HDMI ARC output.
1 | Power/source selection |
2 | Control buttons |
3 | Display |
4 | Play/Pause/Volume |
5 | USB-A Host input |
6 | USB-C DAC input |
7 | SDD slot |
8 | LAN port |
9 | USB-A Host input |
10 | USB-C input |
11 | SD card |
12 | HDMI input |
13 | HDMI ARC output |
14 | HDMI I2S output |
15 | Trigger out |
16 | AES/EBU input |
17 | AES/EBU output |
18 | SPDIF coaxial / Toslink optical input |
19 | SPDIF coaxial / Toslink optical output |
20 | 2x stereo RCA line output |
21 | Balanced XLR line output |
22 | Ground |
23 | Switch GND |
24 | Power switch / Power supply port |
Product type | Audio streamer DAC Preamplifier |
DAC chip | AK4191EQ + AK4499EX |
USB interface | XMOS XU-316 |
Bluetooth chip | QCC5125 |
Processor | Qualcomm Snapdragon 660, 4GB RAM+64GB ROM |
Operating system | Android 12 |
Inputs | 2x USB-C 2x USB-A Host 1x HDMI 1x AES/EBU 1x Optical Toslink 1x Coaxial 1x SSD slot + USB-C 1x SD card slot WiFi Bluetooth |
Outputs | 2x Single-ended RCA 1x Balanced XLR 1x HDMI ARC 1x HDMI I2S 1x AES/EBU 1x Toslink optical 1x Coaxial Bluetooth |
Other connectors | Trigger out |
Supported sampling rates | Native decoding: PCM 32bit 384kHz, DSD256 USB DAC: PCM 32bit 768kHz, DSD512 Coaxial and AES/EBU: 24bit 192kHz Optical Toslink: 24bit 96kHz HDMI input: 24Bit 192kHz |
Supported sampling rates on digital outputs | USB Audio: 32bit 768kHz, DSD512 (support DoP/D2P/Native) Coaxial: 24bit 384kHz, DSD128 (DoP/D2P) Optical Toslink: 24bit 192kHz AES/EBU: 24bit 384kHz, DSD128 (DoP/D2P) HDMI: 24bit 192kHz |
Preamplified output level | Preamp RCA: 4.5+4.5Vrms (1kHz @ 10K ohm) Preamp XLR: 8.9+48.9Vrms (1kHz @ 10K ohm) |
Line output level | RCA: 2.4+42.4Vrms (1kHz @ 10K ohm) XLR: 4.8+4.8Vrms (1kHz @ 10K ohm) |
Frequency response | 20Hz-70kHz (attenuation < 2.8dB) |
SNR | ≥ 131dB (A-Wt) |
Noise floor | LO < 1.8uV (A-Wt) |
THD+N | < 0.00023% (1kHz/0dB @ 10k ohm) |
Streaming services and protocols compatibility | DLNA AirPlay Amazon Music Deezer Qobuz Roon / Roon Bridge / Roon Ready Spotify Spotify Connect Tidal Tidal Connect Web radios |
Power supply | AC 100-240V 50/60Hz |
Dimensions | 430 x 274.5 x 89.5mm |
Weight | 5.65kg |
Color | Silver |
Package | 1x FiiO S15 streamer 1x Bluetooth remote control 1x 3.5mm trigger jack cable 1x USB-C to USB-C cable 1x HDD cage M.2 1x HDD cage installation screwdriver 1x Power cable |
Input | WiFi |
Input | AES/EBU |
Input | USB |
Input | Optical |
Input | HDMI |
Input | SD Card |
Input | SPDIF |
Input | Bluetooth |
Output | RCA |
Output | XLR |
Output | HDMI ARC |
Output | Optical Toslink |
Output | I2S LVDS via HDMI |
Output | Coaxial SPDIF |
DAC / ADC Chip | AK4499EX |
DAC / ADC Chip | AK4191 |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Silver |
Class | N/A |
Networking | Yes |
Remote Control | Yes |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Deezer |
Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | AirPlay |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | DLNA |
