GUSTARD N18 PRO Network Switch 5x RJ45 1x Optical Fiber Black
The Gustard N18 PRO network switch features 5 RJ45 Ethernet ports as well as an SFP fiber optic connector and a BNC connector for external 10Mhz clock. The RJ45 Ethernet ports are based on 10/100/1000Base-T and 1000base-X standards, while the SFP port supports GPON/EPON protocols.
4.7 / 5
By buying this product you get 52 loyalty points
Reference : 18652
529,00 €tax incl.
440,83 € tax excl.
Shipping date: 01-12-2026.
Gustard N18 PRO network switch picture
The Gustard N18 PRO network switch features 5 RJ45 Ethernet ports as well as an SFP fiber optic connector and a BNC connector for external 10Mhz clock. The RJ45 Ethernet ports are based on 10/100/1000Base-T and 1000base-X standards, while the SFP port supports GPON/EPON protocols. With this network switch from Gustard, you can enjoy the flexibility of RJ45 connections, but also the stability and transmission speed of a fiber optic signal. The latter can be used to connect over longer distances.
Gustard N18 PRO: A stable power supply
The N18 PRO's power supply stage features a toroidal transformer and a voltage regulator providing clean, stable current.
Photo of Gustard N18 PRO power supply components
Rear view of Gustard N18 PRO network switch
Product typeFiber optic Ethernet Network Switch
Interface5x RJ45 ethernet port 10/100/1000Base-T and 1000base-X
1x SFP fiber optic connector
1x BNC connector for clock 10MHz (input impedance 50Ω)
Power supply115-230V AC 50/60Hz
Power consumption<10W
Dimensions220 x 50 x 170mm
Package1x Gustard N18 PRO network switch
1x Power supply cable
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorOptical
ConnectorRJ45
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
3 reviews
La suite
A mon avis EtherREGEN plus bonne alimentation+ bonne horloge supérieur mais plus cher aussi vu le Gustard
This review has been posted for GUSTARD N18 PRO Network Switch 5x RJ45 1x Optical Fiber Black
Horloge et signal
Bonjour j'ai aussi une horloge Gustard et un EtherREGEN et je préfère le signal sinusoïdale
A suivre
Jai reçu en l'espace de moins de 24h ! ce switch Gustad , j"ai déja une horloge Gustad
je le compare a un upTone avec une alimentation special de très bonne qualité et donc signal d'horloge externe pour le deux
Pour l'instant le N18 est plus ouvert avec plus de timbres reste que l'uptone a un coté chantant qui est plus présent
Il faut savoir que le signal d'horloge doit être carré (ou est la doc ?)
Le rodage continu (combien de temps ?????)
En tout cas ce switch sonne droit
The Gustard N18 PRO network switch features 5 RJ45 Ethernet ports as well as an SFP fiber optic connector and a BNC connector for external 10Mhz...
