IFI AUDIO LAN IPURIFIER PRO Network Isolator
The iFi Audio LAN iPurifier Pro optical galvanic isolator lets you optimize the LAN Ethernet connection of your audio equipment. Galvanic isolation technology converts the incoming network signal via RJ45 into an optical signal, removing any noise present in the original signal while improving jitter before converting it back to output on a second RJ45 port.
Reference : 19423
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 16-12-2025.
IFI Audio LAN iPurifier Pro Galvanic Optical RJ45 Ethernet Network Isolator
IFI Audio LAN iPurifier Pro picture
The iFi Audio LAN iPurifier Pro optical galvanic isolator lets you optimize the LAN Ethernet connection of your audio equipment. Galvanic isolation technology converts the incoming network signal via RJ45 into an optical signal, removing any noise present in the original signal while improving jitter before converting it back to output on a second RJ45 port. The two RJ45 Ethernet ports are based on the IEEE 802.3x standard, with speeds of up to 1000/100/10Mbps (10/100/1000Base-T). LEDs keep you informed of the device's operating status. Power is supplied via a USB-C port (5V - 1A). A USB power adapter with cable and RJ45 network cable complete the package.
IFI Audio LAN iPurifier Pro connections and LED indicators
Product typeNetwork isolator
Interface2x RJ45
Ethernet standardIEEE 802.3x
Supported speeds1000/100/10Mbps (10/100/1000Base-T)
Power supplyUSB-C 5V 1A DC
Dimensions99 x 92.8 x 24.2mm
Net weight241g
ColorGray
Package1x IFI Audio LAN iPurifier Pro
1x RJ45 cable
1x Power adapter with USB-A to USB-C cable
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorRJ45
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
4 reviews
Easy to install - works well
This review has been posted for IFI AUDIO LAN IPURIFIER PRO Galvanic Optical RJ45 Ethernet Network Isolator
Indispensation pour le streaming
Je m'attendais à une légère amélioration, mais au final dès sa mise sous tension, mes écoutes à partir de Qobuz sont transcendées.
Amélioration de la spatialisation, tout à plus de matière et plus de justesse, une meilleur dynamique, apparition de nombreux micros détails, etc ..
Je recommande vivement :-)
Excellent
Mis à l'entrée de mon streamer, il apporte une amélioration très notable et immédiate sur TOUS les critères d'écoute. Recommandé sans réseve
Le pur et l'impur
Ma première source musicale est constituée d'albums dématérialisés stockés sur NAS en un lieu distinct du local d'écoute. A ses côtés, j'ai installé un barebone exclusivement dévolu à la lecture audio via le Media Center de JRiver. Les deux appareils sont alimentés par leurs SMPS d'origine et l'on sait que ces alimentations à découpage sont susceptibles de polluer le signal audio sortant. Celui-ci transite ensuite par un réseau Ethernet local 100Mbps et donc par le routeur d'une Livebox alimentée elle-même par SMPS. Il était dès lors nécessaire de régénérer le signal audio entrant dans mon DAC avant d'attaquer les étages d'amplification. Le module iPurifier d'iFi Audio arrive sur le marché à point nommé pour s'acquitter de cette tâche. La différence à l'écoute est-elle aussi époustouflante qu'espérée? Sans aller jusque là, je dirais que le son produit me parait plus propre, plus précis, sans altération des timbres ni réduction de la dynamique, bien au contraire. Quoique subtile, cette amélioration de la restitution musicale n'en est pas moins précieuse pour qui désire optimiser son système.
 (3)
The iFi Audio LAN iPurifier Pro optical galvanic isolator lets you optimize the LAN Ethernet connection of your audio equipment. Galvanic isolation...
