Filters
Categories level 1
Brand
In stock
Alain L.
Rapport qualité prix excellent. Parfait dès 39 db.
Bien faire la liaison avec une entrée auxiliaire ou tuner, mais pas...
Pierre J.
A la hauteur...
La finition est de qualité et ces contre pointes malgré un prix serré, jouent leur rôle avec brio, moins de brillances dans les...
Johan v.
Fits smooth as butter and does not seem to have a sound of its own.
New products
  • Ref : 21146
    This Mundorf VL300 coil is build from massive copper wires specially developed to help improve the audio quality when it comes to speaker filtering. This format belongs to Mundorf 's family of high-fidelity components the series of which is made for professional studio use.
    249,00 € 207,50 €Ex.
    In Stock
  • Ref : 21147
    279,00 € 232,50 €Ex.
    In Stock
  • Ref : 21148
    315,00 € 262,50 €Ex.
    In Stock
  • Ref : 21149
    This Mundorf VL300 coil is build from OFC copper wires specially developed to help improve the audio quality when it comes to speaker filtering. This format belongs to Mundorf 's family of high-fidelity components the series of which is made for professional studio use.
    389,00 € 324,17 €Ex.
    In Stock
  • Ref : 21150
    429,00 € 357,50 €Ex.
    In Stock
  • Ref : 21151
    469,00 € 390,83 €Ex.
    In Stock
  • Ref : 21152
    519,00 € 432,50 €Ex.
    In Stock
  • Ref : 21153
    579,00 € 482,50 €Ex.
    In Stock
  • Ref : 21154
    659,00 € 549,17 €Ex.
    In Stock
  • Ref : 21155
    749,00 € 624,17 €Ex.
    In Stock
  • Ref : 21156
    849,00 € 707,50 €Ex.
    In Stock
  • Ref : 21089
    The Ian Canada CmChoker is a two-stage, high-current, wide-voltage common mode filter that effectively suppresses common mode noise introduced by AC power transformers. The CmChoker is specially optimized for audio applications.
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 21071
    These Oyaide INS-BS insulating feet are machined from brass, a material renowned for its mechanical rigidity and vibration dissipation properties. They are designed to limit unwanted resonance while maintaining the structural stability of the devices they support. A carbon composite (FRP) plate is integrated on one side to optimise vibration transmission...
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 21072
    In Stock
    The Electro-Harmonix Gold 12AT7EH is a dual triod tube with gold-plated contacts and equipotential cathodes. It is an excellent choice for preamplification.
    25,90 € 21,58 €Ex.
    In Stock
  • Ref : 21073
    In Stock
    The Electro-Harmonix Gold 12AU7EH is a dual triode tube with gold-plated contacts. Its excellent linearity makes it an ideal choice for preamplification.
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 21079
    In Stock
    The Electro-Harmonix 12AX7EH Gold is a short-plate dual triode tube with gold-plated pins, designed to deliver high gain and extremely low noise thanks to its spiral filament. This tube is a suitable replacement for ECC83 or 7025 tubes.
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 21082
    In Stock
    The Electro-Harmonix 12BH7EH Gold is a medium-gain dual triode tube capable of dissipating 3.5 watts per plate, featuring gold-plated pins for optimal conductivity.
    38,90 € 32,42 €Ex.
    In Stock
  • Ref : 21085
    In Stock
    The Electro-Harmonix 12BH7EH Gold is a dual triode tube with gold-plated contacts and equipotential cathodes. Designed for Hi-Fi applications, this tube is a great replacement for the 6DJ8, ECC88, 6922, E88CC and 7308 models.
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 21075
    In Stock
    The Moondrop Pill are OWS (Open Wearable Stereo) clip-on earbuds with a futuristic design and a transparent capsule-shaped charging case. The clip-on design is ideal for comfortable wear and a secure fit, perfect for listening on the go or during a workout.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 21076
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 21078
    In Stock
    The Moondrop Space Travel 2 Ultra wireless in-ear monitors, an improved version of the Space Travel 2, offer excellent sound performance while maintaining an affordable price. They feature a 13mm planar magnetic driver, Bluetooth 6.0 with LDAC support, improved noise cancellation, and a highly customizable equalizer via the Moondrop app.
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 21133
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 21134
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 21135
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 21136
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 21137
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 21138
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 21139
    99,90 € 83,25 €Ex.
    In Stock
  • Ref : 21069
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 21052
    In Stock
    The UcPure Mini Solo from Ian Canada is a high-voltage power supply with supercapacitors specially designed for sensitive analogue audio applications. Operating in purely passive mode, it contains no active components or negative feedback, ensuring that the output is completely isolated from the input. With its low 1/f noise, minimal ESR and compatibility...
    229,00 € 190,83 €Ex.
    In Stock
  • Ref : 21068
    In Stock
    The UcPure Mini Dual from Ian Canada is a high-voltage power supply with supercapacitors specially designed for sensitive analogue audio applications. Operating in purely passive mode, it contains no active components or negative feedback, ensuring that the output is completely isolated from the input. With its low 1/f noise, minimal ESR and compatibility...
    In Stock
  • Ref : 21047
    In Stock
    The Gustard R30 is a DAC, streamer and preamplifier based on an R2R ladder resistor network to offer high-precision digital-to-analogue conversion, supporting PCM up to 32-bit 1536kHz and DSD up to DSD1024 for faithful and detailed reproduction. Its extensive connectivity allows it to be integrated into a wide range of audio setups. Based on CelWare 3.x...
    3 590,00 € 2 991,67 €Ex.
    In Stock
  • Ref : 21050
    In Stock
  • Ref : 21040
    The SMSL AS400 is an extremely versatile integrated amplifier. It offers numerous advantages, such as a phono input, an HDMI ARC input, a preamplified output for active subwoofers, and two headphone outputs. It also features an audiophile chipset allowing it to support sampling rates up to PCM 32-bit 768kHz and DSD256 while delivering up to 2x 165W of...
    In Stock
  • Ref : 21043
    The SA6 MK2 are in-ear earphones featuring a total of six balanced armature drivers combined with a crossover system that combines physical and electronic solutions for a sound that is both smooth and detailed. Their aesthetics, a combination of wood, gold particles and resin, give each piece a unique design for a look that is both understated and...
    In Stock
  • Ref : 21044
    In Stock
  • Ref : 21018
    The USB DD HIFI TC19CC is a USB cable with a high-end audiophile design. It features DATA conductors made of 4N monocrystalline pure silver and load conductors made of silver-plated OFC 5N copper, all implemented in a parallel structure with 4 flat conductors.
    59,00 € 49,17 €Ex.
    In Stock
  • Ref : 21020
    In Stock
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 21021
    In Stock
    74,90 € 62,42 €Ex.
    In Stock
  • Ref : 21022
    In Stock
    The USB DD HIFI TC19BC is a USB cable with a high-end audiophile design. It features DATA conductors made of 4N monocrystalline pure silver and load conductors made of silver-plated OFC 5N copper, all implemented in a parallel structure with 4 flat conductors.
    119,00 € 99,17 €Ex.
    In Stock
