IAN CANADA UCPURE MINI SOLO Supercapacitor Power Supply Module Kit
The UcPure Mini Solo from Ian Canada is a high-voltage power supply with supercapacitors specially designed for sensitive analogue audio applications. Operating in purely passive mode, it contains no active components or negative feedback, ensuring that the output is completely isolated from the input. With its low 1/f noise, minimal ESR and compatibility with standard 16V supercapacitor packs composed of 6 supercapacitors of 600F for a total equivalent of 100F, it offers a high-performance, affordable solution for powering DACs, I/V stages, preamplifiers and other analogue circuits.
By buying this product you get 22 loyalty points
Reference : 21052
229,00 €tax incl.
190,83 € tax excl.
Shipping date: 01-12-2026.
Ian Canada UcPure Mini Solo Supercapacitor Power Supply Module Kit Class A +/-12V +/-15V
Ian Canada UcPure Mini Solo : Front view
This third generation further improves efficiency and stability, while maintaining a simple and straightforward approach to power conditioning. The absence of active circuits eliminates any colouration or distortion associated with conventional regulation, bringing the UcPure Mini closer to functioning as an ideal voltage source.
Please note that supercapacitors are sold separately..
Ian Canada UcPure Mini Solo : Key points
  • High-performance supercapacitor power supply.
  • Supercapacitors operate in class A, with current flowing in only one direction..
  • The outputs are isolated from the charger and power input in pure mode to eliminate 100% of common mode EMI noise.
  • Supercapacitors can be installed directly on the printed circuit board using copper spacers for high-current applications.
  • 15V and 12V configurations, easily adjustable to +/-15V and +/-12V.
  • Features an output voltage range control mode.
  • High peak charging current of 5A, very fast charging and recharging of supercapacitors.
  • Optimised for a 15V AC input, the UcPures Mini can also operate with a DC input of 19V to 21V.
  • Can be controlled by the integrated/external ON/OFF switch or the control chain (optically isolated) of the entire power supply unit.
  • Optical isolators are used for all internal operating logic.
  • Integrated protection system to prevent supercapacitor depletion and excessively low output voltage.
  • With a powerful SYNC UC charging function. Can recharge supercapacitors during music breaks. This function prevents output voltage drop or protection mode activation, even if you listen to music for a very long time. The SYNC input control signal can be connected to the MUTE signal of a MonitorPi Mini or FifoPiQ7. Multiple UcPures Mini can work together with a SYNC control chain. This signal is optically isolated from the UcPure, so it does not affect the performance of the power supply.
  • Robust design for 24/7 operation.
Ian Canada UcPure Mini Solo : Dimensions
Technical specifications
Product typeSupercapacitor power supply module
Input voltage15V AC
19-21V DC
Output voltage+/-12V
+/-15V
Package1x UcPure Mini 15V/12V PCB
4x 10mm M3 female spacers
8x M3 screws and washers
4x M2.5 spacers
4x M2.5 nuts
2x 15 cm control cables
4x Jumpers
InputScrew terminals
OutputScrew terminals
Output voltage (V)12.0
Output voltage (V)-15.0
Output voltage (V)15.0
Output voltage (V)-12.0
Output current (A)NC
Input voltage (V)19.0
Input voltage (V)15.0
Input voltage (V)21.0
Power SupplyUltracapacitor power supply
IAN CANADA UCPURE MINI SOLO Supercapacitor Power Supply Module Kit Class A +/-12V +/-15V
The UcPure Mini Solo from Ian Canada is a high-voltage power supply with supercapacitors specially designed for sensitive analogue audio...
