The UcPure Mini Dual from Ian Canada is a high-voltage power supply with supercapacitors specially designed for sensitive analogue audio applications. Operating in purely passive mode, it contains no active components or negative feedback, ensuring that the output is completely isolated from the input. With its low 1/f noise, minimal ESR and compatibility with standard 16V supercapacitor packs composed of 6 supercapacitors of 600F for a total equivalent of 100F, it offers a high-performance, affordable solution for powering DACs, I/V stages, preamplifiers and other analogue circuits.
This third generation further improves efficiency and stability, while maintaining a simple and straightforward approach to power conditioning. The absence of active circuits eliminates any colouration or distortion associated with conventional regulation, bringing the UcPure Mini closer to functioning as an ideal voltage source.
Please note that supercapacitors are sold separately..
Technical specifications
| Specifications | |
| Product type | Supercapacitor power supply module |
| Input voltage | 15V AC 19-21V DC |
| Output voltage | +/-12V +/-15V |
| General | |
| Package | 2x UcPure Mini 15V/12V PCB 8x 10mm M3 female spacers 16x M3 screws and washers 8x M2.5 spacers 8x M2.5 nuts 4x 15 cm control cables 8x Jumpers |
| Input | Screw terminals |
| Output | Screw terminals |
| Output voltage (V) | 15.0 |
| Output voltage (V) | -12.0 |
| Output voltage (V) | 12.0 |
| Output voltage (V) | -15.0 |
| Output current (A) | NC |
| Input voltage (V) | 19.0 |
| Input voltage (V) | 15.0 |
| Input voltage (V) | 21.0 |
| Power Supply | Ultracapacitor power supply |
