AUDIOPHONICS XDP001 Power Supply Module 6x10000μF / 50V + 12V
Reference : 4153
29,00 €tax incl.
24,17 € tax excl.
AUDIOPHONICS XDP001 Module d
Thanks to its high output voltage and its many functionalities, the module AUDIOPHONICS XDP001is proving to be formidable to power a DIY amplifier that is both powerful and reliable.
Thanks to the use of a FAIRCHILD 8A 800V diode bridge of origin, this food can indeed reacha rectified voltage of 50V, supplemented by outputs +/- 12Vgenerated by 2 separate regulators.
As far as filtering is concerned, it is no less 6 capacitorsElectrolytic Nippon Chemi-Con with automatic discharge of each 10000uF / 50Vwhich are used.
The output stage also benefits from a complementary filtering made from 4 capacitorsTAIWAN POLYPROPYLENE of each470uF.
Finally, a relay signed OMRON CORPORATIONensuresEffective Loudspeaker Protectionby turning off the power supply in less than 2s when a DC component is detected in the high-level signal at the output of the amplifier.
Requires the addition of a toric 2 X 35V ACmaximum to operate.
Specifications :
  • surfactantn Output: 50V + 12V Max
  • Maximum Current per Diode:8.0 Amp
  • Maximum Supply Voltages:2 x 35V AC
  • Dimensions: 138 x 110mm (L x W)
  • Weight:500g
https://www.audiophonics.fr/images2/4153/4153_XDP001_module_1.jpg
https://www.audiophonics.fr/images2/4153/4153_XDP001_module_2.jpg
