Max cable diameter (mm)
Material
Diameter (mm)
Color
Number of conductors
Insulation material
Tony A.
Très bon rapport qualité prix !
Pour le prix c’est pas mal!
Mon WiiM mini est branché dessus en optique et le tout est relié à mon ampli Sansui du début des...
Tony A.
Bon câble
Câble de qualité qui fait le taff, pas plus pas moins :)
Yves F.
Le produit est de qualité. J'ai un Denon PMA 3000ne et un Roksan K3 V2. J'avais un peu peur qu'il y ait une...
Nylon Sleeves
Discover all our nylon sleeves, allowing an ideal finishing of your DIY cables, having at the same time a protective and aesthetic role.
  • 8,00 € 6,67 €Ex.
    In Stock
  • Ref : 719
    In Stock
    This sheath from Viablue has a magnificent Red, Grey, White and Black colour. It will allow you to offer your cables an aesthetic covering while giving them greater protection for extended durability. The diameter of the sheath can be adjusted from 6 to 14mm.
    2,80 € 2,33 €Ex.
    In Stock
  • Ref : 5261
    In Stock
    This sheath from Viablue has a magnificent Red, Grey, White and Black colour. It will allow you to offer your cables an aesthetic covering while giving them greater protection for extended durability. The diameter of the sheath can be adjusted from 1.5 to 5.5mm.  When your cable measures 5mm, a reduction in the length of 30%.
    1,70 € 1,42 €Ex.
    In Stock
  • Ref : 7837
    In Stock
    This Viablue Stone braided sleeving accepts cables from 2mm to 6mm in diameter, providing effective protection against mechanical stress. Its fine braiding ensures a totally opaque finish.
    2,90 € 2,42 €Ex.
    In Stock
  • Ref : 7838
    In Stock
    This Viablue Stone braided sleeving accepts cables from 5mm to 13mm in diameter, providing effective protection against mechanical stress. Its fine braiding ensures a totally opaque finish.
    2,80 € 2,33 €Ex.
    In Stock
  • Ref : 4120
    In Stock
    This Viablue Stone braided sleeving accepts cable diameters ranging from 13mm to 26mm, providing effective protection against mechanical stress. Its fine braiding ensures a totally opaque finish.
    4,80 € 4,00 €Ex.
    In Stock
