LADDER BACH II R2R Preamplifier Silver
The LADDER Bach II is a preamplifier designed to bridge the gap between audio sources and power amplifiers. It features a discrete Class A balanced design combined with a 60-step relay-based volume control. Designed for versatile Hi-Fi integration, it offers both single-ended RCA and balanced XLR connectors for input and output. In addition, it features a linear power supply with a toroidal transformer, ensuring electrical stability that results in a clear and well-defined sound.
By buying this product you get 97 loyalty points
Reference : 21826
979,00 €tax incl.
815,83 € tax excl.
Shipping date: 20-11-2026.
LADDER Bach II R2R Preamplifier Discrete Balanced Class A Silver
Photo du LADDER Bach II
LADDER Bach II: Aesthetics and design
The LADDER Back II is designed to integrate seamlessly into a Hi-Fi system thanks to its minimalist and practical design. Two symmetrical buttons on the front panel of the preamplifier allow you to turn the unit on and off, select a source, or adjust the volume. The chassis is made entirely of anodized and brushed aluminum alloy for an elegant appearance.
Photo du bouton de volume en façade du LADDER Back II
Photo des entrées RCA du LADDER Back II
LADDER Bach II: Connectors
The Bach II is designed to be versatile, capable of handling as many scenarios as possible. To this end, it features two balanced XLR inputs and one single-ended RCA input, while its outputs consist of one balanced XLR output and one single-ended RCA output. This allows it to accommodate the needs of various sources and amplifiers.
LADDER Bach II: Internal architecture and linear power supply
The power supply is based on an 80W toroidal transformer combined with a filtering circuit that uses ELNA and WIMA capacitors, effectively isolating unwanted interference while stabilizing the voltage supplied to the audio stages. This architecture is complemented by a bank of high-capacity capacitors, ensuring a constant energy reserve and limiting variations during dynamic shifts, which results in controlled background noise and improved signal clarity.
Volume control is based on a microcontroller-driven relay attenuator with 60 steps, allowing for smooth adjustment without channel imbalance, while precision resistors ensure consistent signal processing. This approach is complemented by balanced Class A amplification combined with a unity-gain buffer, preserving the integrity of the signal.
Photo du transformateur du LADDER Back II
Front view of the LADDER Bach II
Schéma de la face avant du LADDER Bach II
1Power switch / Audio source selection / Mute control
2LCD Screen
3Volume control
Rear view of the LADDER Bach II
Schéma du dos du LADDER Bach II
1XLR Input / Right Channel
2RCA Input / Right Channel
3RCA Input / Left Channel
4XLR Input / Left Channel
5XLR Output / Right Channel
6RCA Output / Right Channel
7RCA Output / Left Channel
8XLR Output / Left Channel
9Power Input
Product typeR2R preamplifier
Inputs2x XLR Balanced
1x RCA Single-ended
Outputs1x XLR Balanced
1x RCA Single-ended
THD+N0.0005%
Crosstalk-110dB
Signal-to-noise ratio (SNR)≥ 110dB
Channel separation≥ 105dB
Frequency response10Hz-80kHz
Input Impedance>20kΩ
AC power supply100-240V, 50/60Hz (automatic switch)
Power consumption≤ 25W
Dimensions336 x 304 x 66mm
MaterialAluminium alloy
Weight6.5kg
ColorSilver
Package1x Ladder Bach II
1x Remote Control
1x Power cable
InputXLR
ColorSilver
ClassClass A / AB
Remote ControlYes
LADDER BACH II R2R Preamplifier Discrete Balanced Class A Silver
The LADDER Bach II is a preamplifier designed to bridge the gap between audio sources and power amplifiers. It features a discrete Class A balanced...
