VIABLUE NF-S5 T8 Phono Cable DIN 5 Pin SME Angled to XLR 1.5m Black
The VIABLUE NF-S5 is an angled 90 degree 5-pin DIN (SME) to XLR phono cable designed to transmit very low-level analogue signals between a turntable and a phono preamplifier. It features silver-plated OFC copper conductors combined with a capacitance of approximately 50 pF/m, to limit load effects on the cartridge and preserve the frequency response from the tonearm output, whilst the DIN connection ensures native channel and ground separation.
By buying this product you get 74 loyalty points
Reference : 21872
749,00 €tax incl.
624,17 € tax excl.
Viablue NF-S5 T8 Phono Cable DIN 5 Pin SME Angled to XLR with Ground Wire Silver Plated OFC Copper 1.5m Black
Photo of the Viablue NF-S5 T8 Black cable
The Viablue NF-S5 is an angled 90 degree 5-pin DIN (SME) to XLR phono cable designed to transmit very low-level analogue signals between a turntable and a phono preamplifier. It features silver-plated OFC copper conductors combined with a capacitance of approximately 50pF/m, to limit load effects on the cartridge and preserve the frequency response from the tonearm output, whilst the DIN connection ensures native channel and ground separation. The internal structure is built around a central polypropylene core and polyethylene insulation with low electrostatic charge, which helps to stabilise the cable’s electrical parameters over time.
Designed for phono setups, it features multi-layer shielding combining braided and foil shielding, extended all the way to the connectors to prevent any breaks in continuity. This approach minimises the intrusion of electromagnetic interference whilst utilising a dedicated ground connection to dissipate noise without creating a loop. The XLR connectors ensure a stable connection and low background noise, making them suitable for sensitive analogue systems.
Viablue NF-S5: Conductor Architecture and Electrical Behavior
The silver-plated OFC copper conductors reduce line resistance, preserving the subtle variations in the signal from the cartridge, whilst the capacitance of 50pF/m limits interaction with the preamplifier’s input impedance, preventing any distortion of the high-frequency response.
This approach is extended by an internal design that separates the channels and ground planes from the 5-pin DIN (SME) connector onwards, reducing crosstalk, whilst the continuous shielding and external ground connection ensure controlled dissipation of interference. Together, these features maintain signal integrity right up to the phono stage, under conditions suited to the low-level signals from a cartridge.
Image showing a cross-section of the VIABLUE NF-S5 cable
Schéma
Diagram showing the different layers that make up the VIABLUE NF-S5 cable
1Soft cable sheath
2Banding, fleece
3Spiral shield, tinned OFC strands
4Foil shield, ALU PET silver
5Soft filler
6Inner conductor, silvered OFC strands
7Ground wire, silvered OFC strands
Product typePhono cable
Length1.5m
Connectors1x 90 degree 5-pin DIN
2x XLR
1x Ground wire
Cable conductor materialSilver-plated OFC copper
Connectors contacts platingGold
Conductor capacitance50pF/m
Shield capacitance100pF/m
PackageSold individually
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorXLR
ConnectorDIN
VIABLUE NF-S5 T8 Phono Cable DIN 5 Pin SME Angled to XLR with Ground Wire Silver Plated OFC Copper 1.5m Black
The VIABLUE NF-S5 is an angled 90 degree 5-pin DIN (SME) to XLR phono cable designed to transmit very low-level analogue signals between a...
