AUDIOPHONICS RASPDAC MINI Kit DIY Streamer for Raspberry Pi 4 & DAC ES9038Q2M
4.6 / 5
Reference : 14577
179,00 €tax incl.
149,17 € tax excl.
This RaspDAC Mini Pi 4 has been replaced by its new version, available here : AUDIOPHONICS RASPDAC MINI LCD Kit DIY
Caution: To work, this kit needs to be combined with a Raspberry Pi 4  and a power supply sold separately.
This kit is only compatible with Raspberry Pi 4
RaspDac Mini
Kit Network Player & DAC 32bit 384kHz / DSD 128
Enjoy the features and the finesse of a RaspDac with this kit designed to be assembled by hand.
Ideal to improve your sound system while having fun, this kit is a very intuitive opportunity to learn the basics of audio-oriented DIY method.
The assembly involves neither welding nor special knowledge in DIY. The only tools required are a H5 hex screwdriver and a P4 Phillips screwdriver.
Once mounted, the whole device constitutes a network drive based on Raspberry PI, with all the advantages that it represents in terms of connectivity.
The digital / analog decoding is done internally by a dedicated DAC ES9038Q2M chip, one of the best component in the field of high-fidelity music. This compact model can compete with devices that are way more impressive from their size or their price.
Sabre DAC I-ES9038Q2M
Audiophonics sabre ES9038Q2M
All decoding operations are made thanks to an I-sabre card ES9038Q2M. The latter was specially developed to make the best of a SBC (Raspberry Pi).
This DAC works with its own power stage with DC DC converter and integrated linear regulators. It incorporates the latest optimizations (2020) including an anti-pop relay.
When operated in conjunction with a software solution that has an optimized audio kernel (as is it the case here), the RPI and DAC I-sabre are able to play 32bit 384kHz.
DSD files are also supported up DSD128 (DOP).
The analog output stage is based on two bipolar operational amplifiers NJM 2114 fed with 9V. A third OPA of the same type serves as a buffer. This configuration ensures optimal resolution and a very stable output signal.
Test and review by Audio Science Review
"The AUDIOPHONICS DAC I-Sabre ES9038Q2M finally brings good performance to HAT DACs. It rivals the performance of the higher priced DACs from Allo and Orchard Audio but at lower cost."
Test Qobuz
Remote control from anywhere
interface Raspdac mini
The ES9038Q2M DAC chip offers hardware volume control function (does not damage audio resolution). This hardware volume is controlled remotely from the user interface (smartphone, tablet ....) for maximum comfort and optimal accessibility in any circumstance.
Similarly, playback options and source selection are made on smartphone / tablet (or any other connected device capable of running a web-browser).
Thanks to its software, the RaspDac mini can stream music from DLNA / AIRPLAY compatible devices.
Finally, an infrared remote control also offers access to the basic functions.
Extensive connectivity
By combining the ports of a Raspberry Pi with those of the ES9038 sabre card, the device now offers an impressive connectivity.
The Raspdac Mini has 4 USB-A ports to which the user can plug a hard disk, a USB drive or even a USB CD drive.
Of course, the device is also perfectly at-ease when it comes to play online hosted files through a wired network (RJ45) and non-wired (Wifi / Bluetooth).
The Mini RASPDAC simplifies your audio setup with an extra S / PDIF input port that can connect an extra digital source (CD player, television, gaming platform ... etc). It can thus be effectively integrated in various cases with sufficient flexibility to make all your digital devices enjoy the RaspDac efficiency.
Dimensions of raspdac mini
More compact and still as powerful
Its dimensions of 60 x 90 x 120 mm allow the RaspDAC Mini to fit easily into your audio environment, regardless of size and complexity.
All ports are on the back of the case so as not to damage the visual harmony of your audio-system with visible cables.
Once your RaspDAC is installed and operational, it is not necessary for its operation to redefine wiring or to access the micro SD card. All of its functions can be set wirelessly.
Software solutions for your specific requirements
RaspDac Mini is now capable to handle multiple audio-dedicated software solutions such as Volumio and moOde Audio.
Please note that no software are provided with the kit. You have to pick one from the list below :
Preinstalled moOde Audio
You can get a micro-SD card with a ready-to-use moOde image we edited specifically for RaspDac Mini here.
We made this custom solution to make the process as easy as possible : just insert the SD card in your RaspDac Mini, turn the device on and follow the network configuration. Your RdM is ready to use.
This software solution is suited for user that want to be able to manage more complex integration process in the future. However it might not be the easiest solution to set up for utter beginners.
Preinstalled Volumio
You can get a micro-SD card with a ready-to-use Volumio image we edited specifically for RaspDac Mini here.
Again, the process is really simple, just insert the SD card in your RaspDac Mini, turn the device on and follow the network configuration. Your RdM is ready to use.
If you have no experience with any audio-dedicated software or if you have no idea which solution is the best for you, you will find this one easy to set up and to use.
Or do it yourself
You already have an unused micro-SD (8GB of memory needed) and you are not afraid of doing the installation yourself. Every software image for the RdM is available for free on this webpage for a DIY installation. You can manage a DietPi installation this way as well.
DIY images installer are available for free without time limitations.
Sober and comprehensive display
The front panel display will delight fans of sober aesthetic. The screen is indeed protected by a semi-opaque black acrylic surface, making it invisible when the unit is not powered.
When the mini RaspDAC is active, the screen displays all the information needed to identify the music (track name / album / artist / reading time), playlist (track number).
The screen also displays advanced information that will quickly confirm that the installation works as expected : sampling rate, source ...
Screen raspdac mini interface
Input / Output
4x USB-A Female, 1x Micro USB (Power); 1x stereo RCA, 1x Micro SD In, 1x RJ45 Female, 1x SPDIF Female (complementary digital input)
CAUTION: TO WORK, THIS KIT NEEDS TO BE COMBINED WITH A RASPBERRY PI and a power supply SOLD SEPARATELY.
RaspDAC Mini test by Qobuz & Framboise314
" This RaspDAC Mini Audiophonics streamer deserves to be played with the screwdriver to put it in the case because these efforts will be rewarded with high quality sound reproduction. "
Qobuz - Philippe Daussin
inputs4x USB 2.0-A
1x Coaxial
1x RJ45
1x Micro SD
ExitsX1 RCA Stereo
Supported audio formatsUp to 32bit 384kHz
DSD (DOP) 128
dynamic range129dB
THD + N-120dB
Power supplyUSB-C (5V)
DimensionsHeight: 60mm
Width: 90mm
Depth: 120mm
Weight470g
housing material100% Aluminum
Parts Supplied
Parts supplied mini kit raspdac
Acrylic platex2
Acrylic Supportx1
Aluminum housingx2
1.54 inch OLED Screen (White)x1
Screen PCBx1
I-sabre ES9038 DAC with matching PCBx1
Infrared remote control (No battery)x1
Expansion slot for Female Micro SDx1
Spacers M2.5 - 20mmx2
Spacers M2.5 - 10mmx2
Phillips screw M2.5 - 15.8mmx2
Phillips screw M2.5 - 8.1mmx2
Phillips screw M3 - 7mmx2
Allen screw M3 - 13mmx8
Acrylic Nut M2.5x2
Bracket M3x2
Washer M3x2
RCA Washer Black / Red / Whitex3
RCA Boltx3
Rubber standsx4
USB-A to USB-C cable with switchx1
Assembly instructions can be found in the "download" tab on this same page or on this link
Some information about the start-up....
  • The Micro SD card must be removed from its adapter and then inserted into the reader, taking care to follow the direction, without forcing it.
  • Once the RaspDAC Mini is powered on, a more or less long delay (a few tens of seconds) is required before a display appears on the screen.
  • To control the RaspDAC it is necessary for you to have a computer, a telephone or a tablet also connected to your local network.
  • To access the Volumio web application, simply enter the address shown on the RaspDAC display on your control device (computer, smartphone, tablet).
  • To use the Coaxial input, press the "Menu" button on the remote control so that "SPDIF" appears on the display.
InputMicro SD
DAC / ADC ChipES9038Q2M
Max sampling rate384kHz
Max sampling rateDSD128
9 reviews
Sedat rpi4minidac
I had a problem with my setup as I was very newbie in electronics, I lost the screen display and remote control, but the volumio works and the sound is excellent and now I am waiting for help from the technical team with my problem
This review has been posted for AUDIOPHONICS RASPDAC MINI Kit DIY Streamer for Raspberry Pi 4 & DAC ES9038Q2M
Excellent pour le prix, mais un peu plus avec "ATX" ne m'aurait pas déplu
Il est vrai qu'au début, j'étais déçu, surtout qu'il n'y avait pas le système « ATX » comme le précédent. Bref entre l'allumage et la disponibilité effective de l'application, on ne sait pas si ça s'allume. Dommage ! Juste allumer l'écran (un écran blanc) dès qu'on allume le Raspberry aurait été bien. S'il y avait une astuce je serai preneur.
J'avais lu des critiques sur la finition du boîtier, notamment sur le plexy : oui, ça fait un peu brut, mais ça reste esthétique. J'ai juste eu un petit problème d'assemblage PCB/DAC qui faisait que la télécommande ne fonctionnait pas et ça s'est résolu en le réassemblant correctement.
La télécommande fournie est rigolote (un peu trop sommaire, pas de on/off et un peu jouet) et malheureusement compatible avec l'Apple TV (mais pas l'inverse). Mais comme je comptais utiliser celle de l'ampli, problème résolu !
Quand on fait le compte, c'est 50 € pour le boîtier, le PCB de support avec la diode IR, l'écran OLED et la rigolote télécommande, c'est relativement bon marché.
Alors le DAC oui, là j'ai été surpris tant c'est propre, net et efficace. Le son est vraiment très bon, voire excellent et on peut s'en servir de DAC pour un autre appareil (malheureusement avec le raspberry en activité). Ca c'est génial, du coup, j'ai rangé mon Microméga.
Dommage qu'entre ce kit là et le Evo Sabre il n'y ait pas d'intermédiaire avec un encodeur rotatif et une gestion « ATX ». Si par hasard sortait ce kit où on pourrait récupérer l'écran et le DAC existant, faites-moi signe.
Un tel produit a existé par le passé (Raspdac non mini).
Nous avons essayé sur cette génération de maximiser les fonctionnalités tout en réduisant les couts.
Nothing to say : very good
Hi, I've bough this in addition to my Linn DS in another room and to be honest the sound quality is here.
I am using Openhome on a Raspbian/Raspios distrib (carefull the december is not working with it (issue when spi driver is initialized) but working fine with 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40
After few devs available here : https://github.com/jchassin/ohPlayer , it works with Oled screen scripts provided by Audiophonics in Moode distrib.
So I have a multiroom, Linn DS on one hand and Raspdac Mini on the other, up and running with Qobuz streaming service and driven by Linn Kazoo app on my iPhone.
Please star my github ohPlayer if you use it so that I'll know how interested are people in this dev.
Qualité sonore top, présentation bof.
La qualité sonore est indéniable. Cependant, la boîte et l'aspect du produit fini ne valent pas les 209€.
La boîte ressemble à une... boîte en métal que l'on peut se procurer dans un magasin de bricolage. Il a l'air assez banale.
Le couvercle fumé de l'écran est en plastique et vulnérable aux rayures. Il est arrivé avec une belle égratignure dans le coin supérieur droit! Probablement parce qu'il est seulement protégé par une feuille de papier, qu'il faut enlever avant le montage. Le manuel d'utilisation n'en fait pas mention.
L'écran à l'intérieur n'est pas horizontal et le couvercle arrière semble fait de carton noir. Les deux couvercles avant et arrière ne sont pas au même niveau que le boîtier.
La sortie numérique centrale n'est pas horizontale (endommagée lors du transport ?) et est légèrement orientée vers le bas par rapport à la sortie analogique.
L'emballage est du même niveau de finition que le produit : un peu trop hobby-like à mon goût. Les pièces sont enveloppées de morceaux de carton et de beaucoup de ruban adhésif.
L'emballage de la carte DAC était trop serré et contenait beaucoup trop de ruban adhésif, ce qui rendait le déballage inutilement ennuyeux. La sortie numérique a peut-être été pliée à ce moment-là?
Est-ce très grave tout ça ? Non, pas vraiment... Le système fonctionne, et c'est là tout l'intérêt. Mais le boîtier semble mal adapté et un peu amateur. Dommage.
En fin de compte, je ne pense pas que le boîtier vaille la peine.
Désolé Audiophonics, vous donnez l'impression d'avoir passé plus de temps sur l'électronique que sur la finition.
Bonjour,
Nous vous aurions aidé à la mise en œuvre sur simple demande.
Concernant les pièces endommagées dans le transport, contactez le SAV via le formulaire du site, ils feront le nécessaire.
L’arrière du produit est dans le même acrylique que l'avant et en effet ce produit représente l'entrée de gamme de toute une famille de streamers.
Ravi avec ce Raspdac Mini
Pour commencer ce DAC est facile et amusant à monter, c'est du lego (seul petit piège, mais il faut un peu de challenge : la pièce permettant de caler le lecteur de carte n'est pas tout à fait symétrique, attention à la mettre dans le bon sens car sinon le lecteur ne se cale pas bien dans le cache de derrière, mais cela se corrige juste en remettant la pièce dans le bon sens).
Une fois branché sur mon Atoll IN100 relié à des B&WCM1, que dire à part que je suis ravi de la qualité audio. J'ai essayé les images par défaut Moode Audio et Volumio, et j'ai finalement adopté ce dernier. Et maintenant que j'ai découvert en me connectant par SSH le script de personnalisation du raspdacmini dans le répertoire /home/volumio, je vais le récupérer pour faire des essais en repartant des images par défaut Volumio pour bénéficier des mises à jours automatiques.
