By buying this product you get 59 loyalty points
Amplifier / DAC / Streamer + Black Q Acoustics 3010i Speakers + MEDIA-SUN MS2 2x2m Speaker Cable
With this pack you have a high quality, ready-to-use audio system. All you have to do is plug it in and you can enjoy your audio library and incredible sound reproduction in an instant.
The RaspTouch Amp is an all-in-one version of the RaspTouch. Indeed, this network reader embeds both a DAC ES9023 supporting sampling rates up to 24bit 192kHz and a TPA3118 Class D amplifier of 2x30W. A coherent system that will allow you to supply your Q Acoustics speakers with a clean signal for a stunning performance.
In addition, since the Rasptouch Amp is a network drive using a Raspberry Pi 3 B+, it will allow you to simply enjoy your music, whether it is stored locally or on a server. In this version it comes with a Max2Play operating system license, offering an intuitive and ergonomic interface to navigate within your audio library and enjoy it without limits.
The Q Acoustics 3010i speakers provide surprising sound performance and excellent sound reproduction, including a very well restored low end of the spectrum. With very good levels of distortion, the Q Acoustics 3010i prove to be versatile companions who will be able to accompany you during a long listening session or in front of a movie. The speakers are offered here in their Graphite Black version, offering a sober and elegant design that will fit perfectly into most interiors.
These high quality speaker cables are made of OFC copper conductors to ensure optimal conductivity. They will be able to transport your audio signal efficiently to ensure good audio output.
Rasptouch AMP 9023 | |
DAC | ES9023 |
Amplifier | TPA3118 Class D |
Power | 2x30W |
OS | Max2Play |
Samplinf rate | 24bit 192kHz |
Inputs | 4x USB-A 1x Ethernet RJ45 1x Micro SD slot |
Outputs | 1x RCA Stéréo 1x HDMI |
Screen | 7" Touchscreen |
Color | Black |
Housing | Aluminium |
Q Acoustics 3310 | |
Case type | Reflex 2 voices |
Bass loudspeaker diameter | 100mm |
Treble loudspeaker diameter | 22mm |
Frequency response | 65Hz - 30kHz |
Nominal impedance | 6 Ohm |
Minimal impedance | 4 Ohm |
Sensitivity | 86dB |
Recommanded power | 15-75W |
Transition frequency | 2.6kHz |
Dimensions | 150 x 253 x 252mm |
Weight | 4.1kg / speaker |
Color | Graphite black |
Media Sun MS2 | |
Length | 2x2m |
Section | 2x2.5mm² |
Insulation | PVC |
Conductor | Copper 125 strands, 0.15mm (0.02mm²) |
Cable thickness | 6.8x3.5mm |
Color | White |
Manufacturing | Germany |
