By buying this product you get 43 loyalty points
Network player with SPDIF 75 Ohm digital output
The RaspTouch is evolving! Equipped this time with the excellent ALLO DIGIONE SPDIF interface, it offers a noticeable improvement in terms of ergonomics and a Coaxial SPDIF port doubled by a BNC gold-plated 75 ohm.
The Rapstouch DiGiOne comes with piCorePlayer system installed on the supplied Micro SD card. This way, you can enjoy your streamer directly without having to install an OS beforehand.
Working video of Rasptouch and piCore player interface here
This version of the Rasptouch has to date the most powerful version of digital SPDIF interface dedicated to the Raspberry Pi 3 B+. The ALLO DiGiOne has technical refinements at the level of the best Hifi High end production with one of the best implementations of the digital receiver DIR WM8805. This board has 10 LDO (low drift) regulations, high quality galvanic isolation and a Japanese NDK low jitter clock with 0.4 pico second.
Essai du ALLO DIGIONE PAR Hans Beekhuzen
The DiGiOne Rasptouch offers a complete connection system that will suit most needs. So you'll find 4 USB 2.0 ports and an Ethernet RJ45 port to enjoy your music locally or from your network and an RCA Coaxial, BNC 75ohm and HDMI output. So you have a panel of connectors at your disposal to enjoy your entire audio library.
Mounted in a 100% CNC-machined aluminium housing in France, its black colour and brushed matt appearance give it a modern yet elegant design. It will integrate seamlessly into your high-end audio system.
Input connectivity | |
USB-A 2.0 | x4 |
Ethernet RJ45 | x1 |
Slot Micro SD | x1 |
output connectivity | |
Sortie numérique | x1 coaxial x1 BNC 75ohm |
HDMI | x1 |
Connectiques : Sorties | |
HDMI | x1 |
Raspberry Pi 3 B+ | |
Chipset | Broadcom BCM2837B0 |
Processeur | Cortex A53 64bit SoC 1.4GHz |
Wifi | 2.4GHz et 5GHz IEEE 802.11 b/g/n/ac |
Bluetooth | 4.2 |
RAM | 1GB LPDDR2 |
ALLO DIGIONE GPIO CARD | |
Sampling max frequency | To 24bits 192kHz |
Jitter | 06 Pico Seconde |
Noise Level | 50uV |
Brand | ALLO |
Screen & material | |
Touch screen | 7" tactile capacitif 800 x 400px |
Frame material | Aluminium |
Colors | Black |
VArious | |
Power | Jack DC 5.5/2.1mm - 7.5V 2.9A (fourni) |
Accessory | Carte Micro SD, power adaptator supply Delivered with piCorePlayer installed |
Input | RJ45 |
Input | Micro SD |
Input | BNC |
Input | SPDIF |
Output | Coaxial SPDIF |
Output | BNC |
Output | HDMI |
Max sampling rate | 192kHz |
Color | Black |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Fortuné M.
