DAYTON AUDIO DMA45-PR Passive Radiator
Dayton Audio's DMA45-PR passive radiator is the ideal option for achieving low tuning frequencies from even the most compact loudspeakers. This extremely small passive radiator incorporates all the features expected of a larger model, including adjustable mass, aluminum diaphragm and rubber suspension.
Reference : 20539
8,90 €tax incl.
7,42 € tax excl.
Grantie 5 ans
Dayton Audio DMA45-PRPassive Radiator 60Hz Ø3.8cm
Dayton Audio DMA45-PR: Side view
Dayton Audio's DMA45-PR passive radiator is the ideal option for achieving low tuning frequencies from even the most compact loudspeakers. This extremely small passive radiator incorporates all the features expected of a larger model, including adjustable mass, aluminum diaphragm and rubber suspension. Visually identical to the speakers in Dayton Audio's DMA range, the DMA45-PR lends itself perfectly to the design of compact loudspeakers. Thanks to the threaded rod and wing nut included at the rear, mass can easily be added to adjust the passive radiator response to the specific needs of each acoustic project.
Dayton Audio DMA45-PR: dimensions
Product typePassive radiator
Nominal diameterØ38.1mm (1.5")
Frequency response150Hz - 20kHz
Sensitivity76.9dB @ 2.83V/1m
Voice coil diameterØ19.05mm (0.75")
Weight45g
Total outer dimensions46 x 46 x 29.1mm
Thiele-Small parameters
Resonant frequency (fS)60Hz
Mechanical quality coefficient (QMS)2.75
Compliance equivalent volume (VAS)0.26L (0.0092ft³)
Mechanical compliance of suspension(CMS)2.12mm/N
Mechanical resistance (RMS)0.38kg/s
Moving mass inc. airload (MMS)2.8g
Maximum linear excursion (XMAX)5mm
Surface area of cone (SD)8.6cm²
Materials
ConeAluminum
SurroundRubber
FramePolymer
Mounting informations
Outer dimensions46 x 46 x 29.1mm (1.8" x 1.8" x 1.35")
Cutout diameterØ39.6mm (1.56")
Depth34.2mm (1.35")
Bolt circle diameter50.8mm (2")
Number of mounting holes4
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)38.0
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)5.0
Lowest frequency (Hz)150
Highest frequency (Hz)20000
DAYTON AUDIO DMA45-PR Passive Radiator 60Hz Ø3.8cm
Dayton Audio's DMA45-PR passive radiator is the ideal option for achieving low tuning frequencies from even the most compact loudspeakers....
