ASCILAB F6BS Bookshelf Speakers White / Black (Pair)
Ascilab F6Bs passive speakers are precise, powerful 2-way bookshelf speakers. They feature a 1“ aluminum dome tweeter with custom waveguide and phase plug, and a 6” fiber-cone woofer integrated within a compact sealed enclosure. Indeed, the optimized depth of Ascilab F6Bs speakers makes them easy to integrate on a shelf or desk, while enhancing their sensitivity. This also allows for lower crossover points and reduced distortion for clear sound reproduction. F6Bs feature a 1kHz crossover and support up to 125W of amplification.
By buying this product you get 79 loyalty points
Reference : 20829
799,00 €tax incl.
665,83 € tax excl.
AsciLab F6Bs Bookshelf Speakers 125W 4 ohm 83dB White / Black
Photo of Ascilab F6Bs
AsciLab F6Bs passive speakers are precise, powerful 2-way bookshelf speakers. They feature a 1“ aluminum dome tweeter with custom waveguide and phase plug, and a 6” fiber-cone woofer integrated within a compact sealed enclosure. Indeed, the optimized depth of AsciLab F6Bs speakers makes them easy to integrate on a shelf or desk, while enhancing their sensitivity. This also allows for lower crossover points and reduced distortion for clear sound reproduction. F6Bs feature a 1kHz crossover and support up to 125W of amplification.
For other colors, please contact us via our contact form. The classic black model is available here.
F6Bs models
AsciLab F6Bs: Optimized tweeters
The F6Bs tweeters feature a waveguide and an internal phase plug to manage sound dispersion. These elements avoid phase interference, reduce internal resonance and improve off-axis dispersion. The benefits of this type of configuration can be felt in a flatter frequency response, less distortion and better spatialization of sound.
Zoom in on the F6Bs tweeter
Zoom in on the F6Bs woofer
AsciLab F6Bs: A 6" woofer
Despite their compact size, the 6" woofers of the F6Bs loudspeakers are capable of delivering powerful bass to spaces of up to 25m². High-performance and powerful, these woofers also come with an aesthetically pleasing protective cover.
AsciLab F6Bs: Easy wall mounting
The F6Bs are equipped with a VESA 100 mounting system for quick and easy wall mounting.
F6Bs mounting hole
AsciLab FB6s test by Audio Science Science Review
"Amazing what happens when you follow audio science and engineering to the max: you get a very reasonably priced, gorgeous speaker that is near perfect objectively. Not only is this speaker excellent for surround duty -- with its screw holes in the back for wall mounting -- but it also makes an excellent monitor or desktop speaker.
It is my pleasure to recommend the AsciLab F6Bs speaker. Don't walk, run to purchase a pair!
ASR logo
Product typePassive speakers
Design2 way
Tweeter1" aluminum dome tweeter
Woofer6" fiber woofer with reinforced plastic chassis
EnclosureSealed
FinishMatte
Crossover frequency1kHz
Sensitivity83dB @ 2.83V / 1M
SPL Max. (Full-bandwidth)100dB SPL
SPL Max. (>100Hz)102dB SPL
Frequency response-3dB @ 72Hz / -6dB @ 59Hz
ImpedanceNominal 4 ohm (min 190Hz / 3.7 ohm)
Recommanded amplification50W - 125W
Screw terminal connectionsBanana 4mm
Bare wires
Spades
Dimensions36.8 x 30.3 x 15.4cm
Weight5.6Kg/speakers
ColorWhite and black
Package1x Pair of AsciLab F6Bs
2x Woofer grids
ColorWhite
Impedance (Ω)4
Efficiency / Sensitivity (dB)83.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
Power (W)125.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
ASCILAB F6BS Bookshelf Speakers 125W 4 Ohm 83dB White / Black (Pair)
Ascilab F6Bs passive speakers are precise, powerful 2-way bookshelf speakers. They feature a 1“ aluminum dome tweeter with custom...
