By buying this product you get 79 loyalty points
AsciLab F6Bs passive speakers are precise, powerful 2-way bookshelf speakers. They feature a 1“ aluminum dome tweeter with custom waveguide and phase plug, and a 6” fiber-cone woofer integrated within a compact sealed enclosure. Indeed, the optimized depth of AsciLab F6Bs speakers makes them easy to integrate on a shelf or desk, while enhancing their sensitivity. This also allows for lower crossover points and reduced distortion for clear sound reproduction. F6Bs feature a 1kHz crossover and support up to 125W of amplification.
For other colors, please contact us via our contact form. The classic black model is available here.
The F6Bs tweeters feature a waveguide and an internal phase plug to manage sound dispersion. These elements avoid phase interference, reduce internal resonance and improve off-axis dispersion. The benefits of this type of configuration can be felt in a flatter frequency response, less distortion and better spatialization of sound.
Despite their compact size, the 6" woofers of the F6Bs loudspeakers are capable of delivering powerful bass to spaces of up to 25m². High-performance and powerful, these woofers also come with an aesthetically pleasing protective cover.
The F6Bs are equipped with a VESA 100 mounting system for quick and easy wall mounting.
"Amazing what happens when you follow audio science and engineering to the max: you get a very reasonably priced, gorgeous speaker that is near perfect objectively. Not only is this speaker excellent for surround duty -- with its screw holes in the back for wall mounting -- but it also makes an excellent monitor or desktop speaker.
It is my pleasure to recommend the AsciLab F6Bs speaker. Don't walk, run to purchase a pair!"
Product type | Passive speakers |
Design | 2 way |
Tweeter | 1" aluminum dome tweeter |
Woofer | 6" fiber woofer with reinforced plastic chassis |
Enclosure | Sealed |
Finish | Matte |
Crossover frequency | 1kHz |
Sensitivity | 83dB @ 2.83V / 1M |
SPL Max. (Full-bandwidth) | 100dB SPL |
SPL Max. (>100Hz) | 102dB SPL |
Frequency response | -3dB @ 72Hz / -6dB @ 59Hz |
Impedance | Nominal 4 ohm (min 190Hz / 3.7 ohm) |
Recommanded amplification | 50W - 125W |
Screw terminal connections | Banana 4mm Bare wires Spades |
Dimensions | 36.8 x 30.3 x 15.4cm |
Weight | 5.6Kg/speakers |
Color | White |
Package | 1x Pair of AsciLab F6Bs 2x White Woofer grid |
Color | White |
Impedance (Ω) | 4 |
Efficiency / Sensitivity (dB) | 83.0 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | N/A |
Power (W) | 125.0 |
Number of ways | 2 |
Number of loudspeakers | 2 |
Speaker type | Passive |
Speaker form factor | Bookshelf speaker |
