AsciLab offers white replacement grilles for its F6B speakers. To benefit from a color change, simply select your speaker model with the desired grille change before placing your order. The old grilles will also be shipped to you.
If desired, you can also select a waveguide color replacement using the same method.
Product type | Replacement grille for Ascilab F6B |
Grid color | White |
Package | 2x White woofer grille for Ascilab F6B |
Color | White |
Impedance (Ω) | NC |
Efficiency / Sensitivity (dB) | N/A |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | N/A |
Power (W) | N/A |
Number of ways | N/A |
Speaker type | Passive |
Speaker form factor | Bookshelf speaker |
