DAYTON AUDIO CLASSIC B65 Bookshelf Speakers Wood
Dayton Audio's Classic B65 bookshelf speakers are passive speakers featuring a 16.51cm woofer and a 2.54cm silk tweeter capable of handling up to 40Wrms of power under a 6 ohm load (75W max.). They are equally suited to hi-fi and home-cinema applications, and can be used to sound a room of up to 20m².
Reference : 19618
89,00 €tax incl.
74,17 € tax excl.
This product is temporarily unavailable.
Grantie 5 ans
Dayton Audio Classic B65 Bookshelf Speakers 40W 6 Ohms 85dB 55Hz-20kHz Wood (Pair)
Dayton Audio Classic B65 picture
Dayton Audio's Classic B65 bookshelf speakers are passive speakers featuring a 16.51cm woofer and a 2.54cm silk tweeter capable of handling up to 40W RMS of power under a 6 Ohms load (75W max.). They are equally suited to hi-fi and home-cinema applications, and can be used to sound a room of up to 20m². The Classic B65 features a sealed cabinet to reduce low-frequency distortion. Their sensitivity of 85dB and frequency response of 55Hz to 22kHz make them good speakers at a more than reasonable price. The rear panel features a high-quality terminal block and a practical wall-mounting bracket for easy integration in any space.
Dayton audio Classic B65 speakers highlights:
  • 16.51cm woofer for powerful low frequencies
  • 2.54cm silk tweeter
  • 40W RMS @ 6 Ohms
  • Vintage design and sealed cabinet
  • Wall-mounting bracket
  • High-quality speaker terminals with gold-plated contacts
  • Two speaker cables supplied (3m long)
Dayton Audio Classic B65 speaker components
Dayton Audio Classic B65 woofer picture
Woofer
The durable 16.51cm woofer delivers deep bass.
Dayton Audio Classic B65 tweeter picture
Silk dome tweeter
The tweeter delivers detailed highs for smooth, clear vocals.
An acoustic suspension cabinet
The suspension structure with sealed cabinet greatly reduces low-frequency distortion.
Dayton Audio Classic B65: vintage design
The Classics B65 benefit from a pleasing vintage look, allowing them to be harmoniously integrated into a complete sound system.
Front view of Dayton Audio Classic B65 speaker
Rear view of Dayton Audio Classic B65 speaker
Dayton Audio Classic B65: significant advantages
Dayton Audio B65s feature gold-plated terminal blocks for enhanced conductivity and resistance to corrosion and oxidation. In addition, a wall-mounting bracket facilitates their integration in a home-cinema configuration, allowing them to be installed on either side of a screen quickly and easily. Finally, two speaker cables are supplied for immediate use.
Product typeBookshelf speakers
Speaker typePassives
Number of ways2 ways
WooferPolypropylene 16.51cm
TweeterSilk dome 2.54cm
Frequency response55Hz-20kHz
Sensitivity85dB (2.83V/1M)
Potential output98dB
Power handling40W RMS
75W max.
Recommanded power amplification15W-60W
Nominal impedance6 Ohms
StructureSealed (acoustic suspension)
Crossover frequency4kHz
Dimensions198 x 330 x 170mm
Weight2.7kg/speaker
ColorWood
Package1x Pair of Dayton Audio Classic B65 bookshelf speakers
2x Front grilles
8x Foam adhesive feets
2x Speaker cables
ColorWood
Impedance (Ω)6
Efficiency / Sensitivity (dB)85.0
Lowest frequency (Hz)55
Highest frequency (Hz)20000
Power (W)40.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
DAYTON AUDIO CLASSIC B65 Bookshelf Speakers 40W 6 Ohm 85dB 55Hz-20kHz Wood (Pair)
Dayton Audio's Classic B65 bookshelf speakers are passive speakers featuring a 16.51cm woofer and a 2.54cm silk tweeter capable of handling up...
