Q acoustics 3010i Bookshelf Speakers Graphite Black (pair)
Precision loudspeakers designed to prodivde a great power / size ratio. The cabinet was reworked to allow more space for low frequencies. The Q3010i speakers have all the features for superb sound in a (even spacious) room. For convenience, they can settle on surfaces, stands or wall bracket.
By buying this product you get 23 loyalty points
Reference : 12819
239,00 €tax incl.
199,17 € tax excl.
Q Acoustics 3010i Bookshelf Speakers
A considerable soundstage for very compact speakers
Q-acoustic speakers 3010i
Loudspeakers high precision designed to provude a great power / size ratio. The cabinet was reworked to allow more space for  low frequencies. The Q3010i speakers have all the features for superb sound in a  (even spacious) room. For convenience, they can settle on surfaces, stands or wall bracket.
Q acoustics Q3010i
Great  sound presence and deeper Cabinet
The 3010i speakers remain faithful to the front profile Qacoustic (an acoustically optimal form) but this times gains height and 25% more depth than its predecessors.
This increase in internal volume allows to naturally strengthen the frequency response in the bass. These speakers are therefore able to produce a massive sound with a strong presence, despite an extremely compact design.
This change in format also reduces unwanted noise associated with the resonance of the room as this limits the potential noise reflected from the rear wall, which can be more easily absorbed by the membrane of the speaker.
Strong and high compatibility connectors
Connectors Q acoustics 3010i
The traditional terminal blocks were replaced with low profile brackets.
This not only increases the strength and durability of connectors. These partly internal  sockets also allow deep connections while leaving the possibility to position the speaker close to a wall (including with 4mm banana plugs).
We can therefore use smooth banana plugs, pins or bare son at one's convenience.
Type wellReflex 2-way
Low Driver100mm
High Driver22mm
Frequency Response (+ 3dB, 6dB)65Hz - 30kHz
nominal impedance6 Ω
minimum impedance4 Ω
Sensitivity (2.83 Vrms @ 1m)86 dB
recommended power15-75W
Transition Frequency2.6kHz
Volume4.0 L (244 cu in)
Dimensions150 x 253 x 252 mm
Weight (for each speaker)4.1 kg
ColorGray
Impedance (Ω)6
Impedance (Ω)4
Efficiency / Sensitivity (dB)86.0
Lowest frequency (Hz)65
Highest frequency (Hz)30000
Power (W)75.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorBookshelf speaker
Precision loudspeakers designed to prodivde a great power / size ratio. The cabinet was reworked to allow more space for low frequencies. The...
