HiVi SWANS M10 HiFi 2.1 Hi-Fi Speakers kit black
Reference : 11207
159,00 €tax incl.
132,50 € tax excl.
The Swans M10 is a 3-way 2.1 kit amplified for multimedia gamer use or the high fidelity sound of a room.
With a high-quality assembly quality in its black version, here is a well-built 2.1 High fidelity kit.
The 2-way satellites are closed and composed of a 8cm midrange speaker and a textile dome tweeter.
The case uses a 13cm long excursion loudspeaker, as well as 2 Bass-Reflex vents.
This European version features a sound signature adapted to the Western market. This kit 2.1 is shielded, so as not to interact with a CRT screen.
Subwoofer:
System: 1-way vented box active system Driver Configuration
Woofer:5 "
Frequency range: 42-5kHz
Power rating: 10-40W
Integrated Amplifier:
Frequency range: 100Hz-20kHz
Nominal power : 2 x 8W RMS
Noise signal ratio: > 88dB
Distortion: THD <0.01% (8Ω @ 1KHz @ 1W)
Input sensitivity: 600mV
Input impedance: 22KΩ
Crosstalk: > 60dB
Other:
Finish:PVC matt black, with HP white
Dimensions:245 x 258 x 172mm
Net peas:4.2 kg
satellites
System:2-way 1st sealed box system
Woofer:3 "
Tweeter :20mm
Plage of frequency: 140Hz - 20kHz
Distortion:280Hz - 20kHz = 1% (2.83 V / 1m)
Sensitivity: 87dB 2.83V / 1m
Nominal impedance:
Power rating:1-20W
Other:
Dimensions:110 x 100 x 172mm
Net weight :0.84 kg
[Img-18810-left-thickbox_default]
[Img-18813-left-thickbox_default]
