MATRIX ELEMENT H USB 3.0 Controller Jack DC PCIe Femtoclock Crystek Power Filter
By buying this product you get 36 loyalty points
Reference : 13543
363,00 €tax incl.
302,50 € tax excl.
MATRIX ELEMENT H
USB Matrix Element H
This USB interface is designed to be mounted directly into your desktop computer on a PCIe connector. Its function is to improve the audio performance of your machine by equipping it with a high quality filtered USB output
This USB 3 output is dedicated to audio precision and offers outstanding performance in terms of power supply noise.
It also embeds a filtered DC 9-12V external power supply input allowing it to upgrade the overall efficiency with a better power supply without causing additional space loss . This USB interface is ideal for an ambitious audio system centralized on a fixed computer as a primary digital source.
Internal USB audiophile hifi
Crystek CCHD-575 femtosecond Oscilator
The interface works with an extremely low noise femtosecond clock Crystek CCHD-575.
The latter controls a USB 3 chip Texas Instruments with a dedicated independent channel for the audio stream. Such a configuration allows the circuit to almost completely bypass the motherboard integrated USB interface, thus enjoying an audio line isolated from other USB data lines used on the machine.
Integrated filtered power
Several filter unit are integrated within the stage power stage. They work using solid capacitors and high intensity low noise voltage regulators.
When the interface is powered internally. the circuit provides sufficient filtering to eliminate high frequency noise caused by the computer switching power supply.
USB power passive filtering Matrix Audio Interface hi-fi
USB power source audiophile DAC PC
The USB 3 port provides 5V / 1.5A max output, enough power to supply a proper desktop DAC in very limited space.
Conversely, if your DAC has its own power supply, a switch on the front can power off the USB output. In this scenario, the USB output 3 is completely dedicated to data and suffers no interference from any outgoing power.
To summarize, three powering strategies are possible:
  • Ext: the interface is powered by an external power supply (cleaner sound if used with a quality power supply, but needs more space)
  • Int: the interface is fed by the computer power supply. In this configuration, the interface is capable of filtering most of the supply noise, however the result will be less accurate than a clean external power supply
  • Off: Interface is not powered (USB does not issue 5V output). This configuration is ideal if your interface directly is connected to a DAC equiped with its own (quality) power supply.
matrix element h housing protection rfi emi
Aluminum Housing
In order to protect the high quality electronics components, the whole PCB is protected by a full shielded aluminum housing. The latter blocks EMI RFI interferences from other elements in your computer (starting with the video card).
TypeUSB controller
Standard
xHCI
USB-3
CompatibilityWindows
Linux
Input connectorPCIe x1 Gen2
Outputs1x USB-A
Voltage / output current5V / 1.5A
external power9-12VDC ≥1.2A
DC-Jack 5.5 / 2.1mm
Dimensions144 x 64 x 23mm
(Projection range)
Package Contents
USB Controller ELEMENT Hx1
mounting cradle (standard size)x1
mounting cradle (1/2 height)x1
InputJack DC 5.5/2.1mm
OutputGX12
OutputS/PDIF
OutputJack 4.4mm
OutputPH 2.0mm
OutputHDMI
OutputJack DC 5.5/2.1mm
OutputMIDI
OutputGPIO
OutputMolex
OutputOptical Toslink
OutputJack 2.5mm
OutputJack DC 4.0/1.7m
OutputI2S via RJ45
OutputKingsound / Stax 5 Pin
OutputScrew terminals
OutputI2S LVDS via HDMI
OutputI2S
OutputMini HDMI
OutputMMCX
OutputBluetooth
OutputMicro HDMI
OutputJack 3.5mm
OutputSubwoofer
OutputXH 2.54mm
OutputCoaxial SPDIF
OutputJack DC 5.5/2.5mm
OutputSchuko
OutputBNC
OutputSPI
OutputUSB
OutputJack 6.35mm
OutputJack DC 3.5/1.35mm
OutputAES/EBU
OutputDIN 5
OutputOptical Mini-Toslink
OutputACSS
OutputIEC C13
OutputI2S via DVI
OutputKingsound / Stax 6 Pin
OutputWiFi
OutputSpeaker terminal
OutputRJ45
OutputOptical Fiber
OutputCIEM 0.78
ColorSilver
14 reviews
Tranquillité et musicalité
Après quelques petites cartes qui effectuent leur job correctement, la carte MATRIX ferme la porte pour laisser le bruit dehors MAIS VRAIMENT et permet une belle musicalité, elle apporte aussi une très bonne stabilité du signale.
Satisfait de cette achat.
This review has been posted for MATRIX ELEMENT H USB 3.0 Controller Jack DC PCIe Femtoclock Crystek Power Filter
Predrag
I bought Matrix Element H and external LPSU Audiophonics 12V.
The sound of my Pegaus DAC improved, less sibilance and digital glare, more musical.
Audiophonics are very cooperative and friendly as usual.
Excellente interface usb!
Je l'utilise depuis quelque temps déjà et je confirme l'excellente musicalité de cette Matrix élément H! La scène sonore est large,
profonde,précise et aérée.Les timbres sont nuancés et naturels.
Pas de crispation mais une restitution fine,plutôt douce et sans
coloration excessive. La musique s'écoule avec fluidité,un certain
raffinement,tout en procurant une agréable sensation de réalisme
et de naturel. C'est donc un excellent produit!
Patrick
Qualité et tranquilité au rendez vous
Destiné a un usage Home studio sur une base de carte mère Asus de 2012
et une carte son externe Apollo.
cette fameuse carte a résolue mes problèmes de parasites EMI générés par le processeur de type I7 Intel (bruit typique de travail lors d'ouverture de programmes ou déplacement de la souris). Mais pas que car sa a aussi amélioré le temps de latence a moins de 2 millisecondes avec a la clef une net amélioration au niveau de la spatialisation sonore et clarté des timbres.
un investissement sert élevé pour cette petite carte mais le prix de la tranquillité et de la qualité sonore.
Ecoutez la différence
Acheter avec une alimentation ifi Audio iPOWER et un filtre alimentation ELFIDELITY AXF-107. Très content de mon achat, meilleur séparation des instruments, une écoute nettement plus agréable. je craignais un peu l'installation ayant un système à base linux et passthrough de la carte USB à une VM Windows, mais aucun problème de prise en charge .
