The 7Hz Artemis39 is a compact portable DAC, equipped with an ESS ES9039Q2M chip offering rich, detailed sound and supporting high-resolution audio streams up to PCM 32bit 384kHz and DSD256. What's more, this DAC ensures low power consumption, which combined with an 1100mAh battery, provides comfortable autonomy with up to 10 hours of continuous playback.
The Artemis39 features a USB-C audio input and dual output with single-ended 3.5mm jack delivering up to 320mW into 32Ω and balanced 4.4mm jack delivering up to 405mW into 32Ω. This output power is delivered by a high-performance ES9603Q amplifier chip.
This connectivity is complemented by Bluetooth via a QCC5125N chip, enabling wireless streaming of music to the Artemis39 and thus reducing cable clutter. The high-definition Bluetooth codecs aptX, aptX LL, aptX HD and LDAC are supported, for quality listening even when wireless.
The 7Hz Artemis also has a built-in microphone, so you can answer calls quickly and easily. Ideal for use on the move.
Product type | Portable DAC |
Inputs | USB-C Bluetooth |
Outputs | 1x Single-ended Jack 3.5mm 1x Balanced Jack 4.4mm |
DAC Chip | ES9038Q2M |
Amplification chip | ES9603Q |
USB Interface | SA9137L |
Bluetooth chip | QCC5125N |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX LL, aptX HD, LDAC |
Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD256 |
Built-in microphone | Yes |
Battery capacity | 1100mAh |
Built-in DAC filters | x8 |
SNR | 129dB (wired) |
THD+N | 0.0002% (wired) |
Power output | Jack 3.5mm: 2x 320mW @ 32Ω Jack 4.4mm: 2x 405mW @ 32Ω |
Dimensions | 78 x 39 x 14mm |
Weight | 63g |
Body material | Metal |
Color | Black |
Package | 1x 7Hz Artemis39 1x USB-C cable |
Input | USB |
Input | Bluetooth |
Output | Jack 4.4mm |
Output | Jack 3.5mm |
DAC / ADC Chip | ES9039Q2M |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | Black |
Networking | No |
Remote Control | No |
