AUNE BU1 Portable DAC Discrete Headphone Amplifier 32bit 768kHz DSD512
The Aune BU1 is a high-end portable DAC with integrated headphone amplifier, designed to provide the best sound reproduction. It thus supports high sampling rates, up to PCM 32bit 768kHz and DSD512. The amplification section benefits from a particularly efficient discrete architecture. In addition, the device offers perfect compatibility with Apple and Android devices and will therefore adapt to each other's hardware.
Reference : 14083
299,00 €tax incl.
249,17 € tax excl.
Last items in stock !
Shipping date: 20-06-2025.
Aune BU1
Portable DAC ES9038Q2M & Discrete Headphone Amplifier 32bit 768kHz DSD512
Aune BU1 Amplificateur Casque Portable Discret 32bit 768kHz DSD512
The best partner for your smartphone
As smartphones support increasingly high audio file resolutions and online music is becoming more and more abundant, the use of a Hi-Res DAC with headphone amplifier has become an essential requirement for anyone who wants to enjoy their music in high quality. Thus, connected to the BU1, your smartphone instantly becomes a Hi-Res audio player.
Enjoy your high resolution files
Simply connect the BU1 to your computer to be able to decode up to PCM 768kHz and DSD251. All you have to do is connect your computer to active speakers or headphones, and enjoy a lively sound scene and incredible clarity.
A rigorous selection of components
High quality SR PCBs for optimal signal transmission and high frequency reproduction, high precision BI film potentiometer, ultra low jitter clock for higher sound purity or ceramic COG capacitors for lower distortion level, the BU1 does not leave room for chance!
Positive and negative voltage regulator
Like its big brother the B1s, the BU1 uses positive and negative voltage regulators to ensure constant optimal operation of the device, while maximizing its performance and promoting its dynamic range.
Discrete amplification stage
The BU1 uses a DC-feedback amplification circuit and is totally discreet. This architecture provides a better frequency response and an excellent transient response. For this purpose, high-performance ON transistors are integrated.
Beautiful housing
The chassis of the BU1 is machined with a CNC directly in an Aluminium block. Precisely cut, its design does not include any screws for a perfect result. With its brushed finish and beautiful, perfectly integrated buttons, the BU1 is not only robust, but also has a sublime aesthetic.
Outstanding balance control, long autonomy
Current, ability to accompany headphones, dimensions, performance, everything is balanced in this DAC / headphone amplifier. In addition, its 4000mAh battery ensures an extremely clean power supply and guarantees an excellent autonomy, up to 8 hours.
Excellent specifications, transparent rendering
The BU1 offers excellent technical specifications: a distortion of only 0.00076% and a noise level at 1.97µV, allowing deep bass and impressive richness to be reproduced.
In addition, the device has been calibrated using real instruments and numerous reference audio contents for reference, in order to provide both neutral and musical sound.
Product typePortable DAC and Headphone Amplifier
DACES9038Q2M
Input1x Micro USB (DAC)
Outputs1x Jack 3.5mm (Line output)
1x Jack 3.5mm (Headphone output)
Supported sampling rates (Micro USB input)PCM up to 32bit 768kHz
DSD up to DSD512
Output level (Line output)2Vrms
SNR (Line output)120dB
THD+N (Line output)0.00076%
Output power (Headphone output)30mW @ 300Ω
THD+N (Headphone output)0.0009%
Case materialBrushed Aluminium
ColorGold and brown
Dimensions (LxPxH)65 x 126 x 18mm
Package1x Aune BU1
1x USB cable
1x USB-C to Micro USB cable
OutputJack 3.5mm
DAC / ADC ChipES9028Q2M
Max sampling rateDSD512
Max sampling rate768kHz
ColorOther
ColorBrown
ColorGold
ClassClass A / AB
The Aune BU1 is a high-end portable DAC with integrated headphone amplifier, designed to provide the best sound reproduction. It thus supports high...
