Realtek ALC5686 Male Lightning MFI to Female Jack 3.5mm Hi-Res 32bit 384kHz DSD128
This adapter integrates a male Lightning MFI connector and a female 3.5mm jack. It also embeds a Realtek ALC5686 DAC supporting high sampling rates up to PCM 32bit 384kHz and DSD128. The cable itself benefits from a beautiful design, composed of copper and silver conductors braided together and insulated by a transparent sheath.
Product type | Lightning / Jack 3.5mm DAC adapter |
Connectors | 1x Male Lightning MFI 1x Female Jack 3.5mm |
Length | With connectors : 12.5cm Without connectors : 7cm |
DAC Chip | Realtek ALC5686 |
Conductors material | Copper Silver |
Supported sampling rates | PCM up to 32bit 384kHz DSD up to DSD128 |
SNR | 125dB |
Dynamic range | 113dB |
THD+N | 0.0003% |
Frequency response | 20Hz-40kHz |
Output impedance | 16-300Ω |
Input | Lightning |
Output | Jack 3.5mm |
DAC / ADC Chip | AL5686 |
Max sampling rate | 384kHz |
Max sampling rate | DSD128 |
Color | Silver |
Networking | No |
Remote Control | No |
Contacts Material (Connector) | N/A |
