DD TC35 PRO TETRIS Adapter Headphone Amplifier DAC USB-C Hi-Res ES9281AC 32bit 768kHz DSD512 MQA
The DD TC35 Pro Tetris is a small USB-C male to 3.5mm female adapter, integrating a DAC and headphone amplifier ES9281AC. It is therefore ideal for use with a smartphone that does not have a headphone output.
Reference : 15416
89,00 €tax incl.
74,17 € tax excl.
DD TC35 Pro Tetris
DD TC35 Pro Tetris Adaptateur Amplificateur Casque DAC USB-C Hi-Res ES9281AC 32bit 768kHz DSD512 MQA
The DD TC35 Pro Tetris is a small USB-C male to 3.5mm female adapter, integrating a DAC and headphone amplifier ES9281AC. It is therefore ideal for use with a smartphone that does not have a headphone output. High quality, it supports high sampling rates, up to PCM 32bit 768kHz and DSD512, but also MQA files (Master Quality Authenticated) for a high quality sound reproduction.
Product typeUSB-C / Jack 3.5mm adapter
Headphone amplifier & DAC
DAC ChipES9281AC
Input1x Male USB-C
Output1x Female Jack 3.5mm
Frequency response20Hz - 40kHz @ 0.032dB
Output power≥ 30mW @ 16Ω
≥ 62mW @ 32Ω
≥ 7mW @ 600Ω
SNR-118dB
THD+N0.0004%
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
MQA
Dimensions28 x 28 x 8mmmm
Weight8g
OutputJack 3.5mm
ColorGray
The DD TC35 Pro Tetris is a small USB-C male to 3.5mm female adapter, integrating a DAC and headphone amplifier ES9281AC. It is therefore ideal for...
